TBI swap help! Please.
Discussion in 'The Garage' started by clarkjw24, Feb 15, 2005.
  1. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    TBI swap help! Please. Need TBI GODs
    I'm swapping in a tbi setup into my K5. I've got an 84 desiel silverado fuse block. I'm using the firewall back harness from an 87 Silverado K10. I've got 5 wires on the outside row that will not meet a connector in the fuse block. Could someone please help me identify these and how to hook them up. I've got picks of the wires and pics of some plugs that I don't know where to hook. I bought the whole 87 truck but used the fuse block in another K5.
    Pink and white
    Orange
    Brown
    Brown and white
    Dk Brown
    Plug on pass side of block
    Do I need this off of the old block
    is this brown and white wire a ground?
    I've got no where to plug this two wire plug
    Could someone please help me.
  2. loafer
    loafer 1/2 ton status
    Aug 19, 2003
    634
    Lyman, Maine
    pictures two and three are the knock sensor plug and knock sensor. You don't have to use it, but it's nice to have.
    Pictures four and five is the coolant temp. sensor. You'll need to find a place on your manifold to install the sensor, as this ecu uses the sensor to determine the propper enrichment for cold starts and is used to set the idle speed.
  3. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    I've got the coolent plug hooked up in pic 4 but was wondering about the brown and white wire sticking up. I think it may be a ground? Pic 5 is another two wire plug that reaches only to the base of the tb. Maybe it went to egr or smog stuff which I'm not running. I'll grab the knock sensor off of the old block and hook it up.
    Anyone on the five wires in the first pic and do they need power?
  4. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Any more info for me guys?
  5. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    TTT for the night wizards.
  6. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,921
    331
    Fort McMurray, Alberta
    Brown and white is ground on my TPI setup. I'll have to find a TBI wiring diagram to see if I can help with the rest. Don't hold me to this, but I think that two pole connector with the orange weather seal is for the electric fan... There are a number of other things it could possibly be though, an emissions connector (air divert, air select, canister purge, egr etc) MAT (manifold air temp) sensor, or something like that.
    The easiest way to help us help you is to let us know what service number your ECM is, and where those wires in the fuse box are coming from / going to.
  7. dyeager535
    26,975
    Do a search for one of my posts regarding TBI fairly recently. I wasn't the original one to post it, but some TBI wiring schematics are reference by me in it.
    Last plug pic is something like EVAP, AIR, or EGR solenoid.
  8. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Thanks a million. Found the webshots link to the schematics. That should do me.:xmas:
