TBI Swap
Discussion in 'The Garage' started by 83bowtyblazer, Apr 15, 2002.
  1. 83bowtyblazer
    83bowtyblazer 1/2 ton status
    Jul 29, 2001
    132
    Ft. Dix, NJ
    Hey everyone, I got a question about a TBI swap. I just bought an 87 K5 for 500.00. The motor and tranny are shot. I was wondering if it's possible to swap the TBI setup from the 87 and put it on my 83, and what mods do I need to do in order to accomplish this task. Thanks in advance.
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    pull the heads and intake, place them on yours, then get all the sensors off the donor, pull the computer out and wire it all up, just go from one to the next . Or get a painless wiring kit for $300
  3. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    If you do this, I'd also get the interior harness from the donor, it will make for a much cleaner and simpler swap. Wish I had.
    Also, you don't have to swap the heads, you can modify the 4 center bolt holes on the TBI manifold to work, use an aftermarket one, or use a 4 barrel one w/an adapter plate (try the thirdgen.org site for info on this).
    Pete
