tbi tach output?
Discussion in 'The Garage' started by ryan22re, Dec 27, 2005.
  1. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    installing a cheapo tachometer today, and am wondering where would be the best place to pick up the rpm signal.
    i was thinking the white wire coming from the coil, but i seem to remember the esc module having a tach output.
    id really like to pick up the signal at the ecm, so i can avoid wiring under the hood. im thinking it should be the same white wire from the coil, just under the dash. oh yeah, its an 87.
    ryan
  2. opfor2
    opfor2 1/2 ton status
    Oct 28, 2002
    375
    Ventura County, CA
    There should be a tack output wire on the HEI distributor
  3. sweetk30
    Nov 1, 2004
    25,554
    548
    horseheads , ny 14845
    the coil wires have a extra plug not used and this is the wire to hook it upo to. the tbi dist dont hook up like the old hei ones do.
  4. redneckdude
    redneckdude 1/2 ton status
    Feb 21, 2004
    578
    Augusta, GA
    I asked about this a while back...there is an extra terminal on the coil for tach signal. Find a thread abotu this started by me and theres a pic in it from another member that shows right where it is.
  5. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    yeah i found it.
    thanks for the help.
    it's working good.
    ryan
