TBI timing question
Discussion in 'The Garage' started by yunit, May 1, 2004.
  1. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    Lost my manual and have two quick questions.
    What is the base timing for an 87 TBI engine, 0 degrees?
    What sensor do I need to disconnect to set the timing, the one right by the thermostat?
    Thanks, Pete.
  2. 1-ton
    Apr 17, 2004
    2,890
    169
    Las Vegas, Nevada
    It has been a while since I have done this, but I think the computer interface for the ignition timing is located on the right side (passenger side) of the firewall in the engine compartment.
  3. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Base timing is O but you can boost it up to 4 without problems If you run mid grade gas or better. Will help performance and milage.
    Look on the firewall by the power brake booster. you will see a tan wire with a black stripe hanging out of a big ol wire loom. Disconnect it at the weather tite connector and set the timing. Reconnect after setting timing and you are done.
