Tbi timing
Discussion in 'The Garage' started by fatbob, Nov 11, 2005.
  1. fatbob
    fatbob 1/2 ton status
    Jul 3, 2003
    420
    Phoenix, Az
    :ears: Anyone know where the ESC connector is on a 1988 v3500, or have a pic?
    I will need to disconnect it to set my timing, and I know they say it is near the blower motor on the thirdgen website. But either I looked right at it and didn't recognize it, or it must be somewhere else on our trucks.
    Bob
  2. xpndbl3
    xpndbl3 1/2 ton status
    Jul 30, 2005
    510
    orland park, IL
    typically it's a one wire plug that is located near the master cylinder/brake booster. I believe it's a brown wire, but it's been a while since I've set the timing on my motor. hope this helps, also it might be inside one of the wire looms if it's never been set before.
  3. lrazer
    lrazer 1/2 ton status
    Oct 3, 2004
    231
    Mokena, IL
    on mine it was by the brake booster, it is a single wire connector in line in the loom would post a pic but i am 300 miles away from my truck right now
  4. jays68yak
    jays68yak 1/2 ton status
    Feb 27, 2003
    973
    Gilroy, CA
    On my 88 harness its right next to the firewall connector, brown wire with a black strip.
    On my 94 truck its under the glove box, same color wire.
  5. fatbob
    Jul 3, 2003
    420
    Phoenix, Az
    Thanks guys. :thumb:
    I found it near the brake booster like you said.
