tbi to carb swap
Discussion in 'The Garage' started by K5Dan, Apr 1, 2003.
  1. K5Dan
    K5Dan 1/2 ton status
    Nov 15, 2002
    583
    Port St. Lucie,Fl
    swapping an 87 blazer to carb.wondering if the 700r4 is controlledby the computer in any way?also would i need a new bracket for the acc. and t.v. cable thats it for now but will have more ?'s on this swap as it unfolds /forums/images/graemlins/eek.gifthanks /forums/images/graemlins/ears.gif
  2. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    Why are you switching to a carb?
    Bowtie Overdrive in Hesperia makes a nice mounting bracket kit for the TV cable.
    The 700R4 is not computer controlled, only the 4L80E version is.
  3. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    When you pull your TBI, go ahead and box it up and I'll pay shipping! /forums/images/graemlins/thumb.gif
  4. K5Dan
    Nov 15, 2002
    583
    Port St. Lucie,Fl
    thanks 88 /forums/images/graemlins/thumb.gif
  5. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    The 700r4's TC lockup IS controlled by the computer...So if you swap to a cab, you must get a TC lockup kit...You can probably get one from Jegs or Summit for like $30 or so...The 700 is a popular swap for rodders so there are many options available...
    Chris
  6. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    ditto, send me your TBI set up! /forums/images/graemlins/grin.gif
    j
  7. 88Silverado
    Mar 13, 2003
    2,664
    oops...forgot about lockup. BTOD also makes an adaptor for the lockup, basically when it shifts into OD, it locks up immeadiatly. I believe its done just by applying 12V to the trans, dont forget to get the new brake switch which will release the lockup when the brakes.
    look at http://700r4.com/sitemap.html
    Again, why are you swapping from a TBI to a carb? /forums/images/graemlins/confused.gif
    If you want more power, buy the Holley TBI unit and a modified chip from Hypertech. The holly TBI as about 670CFM, more than enough for any smallblock setup and you dont have to worry about flooding, loading up, standing it on its tail, etc.
  8. K5Dan
    Nov 15, 2002
    583
    Port St. Lucie,Fl
    I've had nothing but trouble with the tbi.it has been a pain for me.the carb stalls on an incline where as my tbi stalls on the street /forums/images/graemlins/frown.gifso i got a carbed 406 im going to swap in instead.i run mostly mud with the blazer /forums/images/graemlins/cool.gifand anything else i can fit it through /forums/images/graemlins/thumb.gif
  9. 88Silverado
    Mar 13, 2003
    2,664
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
