tbi too leane!
Discussion in 'The Garage' started by mightywhitey_k5, Jan 31, 2005.
  1. mightywhitey_k5
    mightywhitey_k5 Registered Member
    Sep 3, 2004
    74
    I am sick of smelling rotten eggs every time i let off the gas with my back window down. some one please help. Thanks.
  2. mightywhitey_k5
    Sep 3, 2004
    74
    SORRY for accidently double posting i f-ed up dose any one know how to ritchen my O2/gas mixturt on my 87 tbi?
  3. dyeager535
    26,976
    Do some research on catalytic converters. Or have you already and found that this is indicative of a lean condition?
    Friend put a Catco(?) converter in his Monte Carlo, ever since, rotten egg smell.
    The stuff I've read says that is a "typcial" smell, but I don't think so in his case, it shouldn't be so bad.
  4. 1badv10
    1badv10 Registered Member
    Feb 26, 2004
    74
    new york
    i also have been told that the "rotten egg" smell means that the cat is working properly.
    as for making it run a lil richer look into www.cfm-tech.com they have an adjustable fuel pressure reg. that goes into the throttle body and a guage to set it to the optimal ratio for your modifications.
    just wondering are you getting a check engine light or anything like that?
  5. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    i have just the opposite- mine is too rich. Im thinking the o2 must not be working correctly, but...
  6. loafer
    loafer 1/2 ton status
    Aug 19, 2003
    634
    Lyman, Maine
    too rich, not too lean
    The rotten egg smell is a result of a rich A/F, not lean. The cat is not getting hot enough to kick of the reaction.
    Replcase your O2 sensor and check for leaky injectors. If this is only happening on deceleration I would also check the MAP sensor. Make sure there isn't a leak in the vacuum line for the MAP.
  7. mightywhitey_k5
    Sep 3, 2004
    74
    thanks for the info fellas. i didnt think a bout the cats but i dont think it could be them, i just instaled a dule set up compleat from the man all the way back. That adjustment sounds cool ill have to check that out.
  8. dyeager535
    26,976
    Dual setup? Dual cats?
    I'm no exhaust expert, but I do know they need to heat up to a certain point to "fire". If you cut the amount of exhaust passing through a cat by 50%, heat "loss" could be a factor.
