TBI Trouble codes
Discussion in 'The Injection Section' started by eagle mark, Sep 28, 2008.
Thread Status:
Not open for further replies.
  1. eagle mark
    eagle mark 1/2 ton status
    Nov 18, 2004
    3,289
    North Idaho!
    If your having a Check Engine Light come on then here's a way to check what error code the ECM is reporting. There are some GM explanations and exact step by step ways to troubleshoot at the bottom of this post in a dowloadable PDF document.
    Trouble Codes
    THE ALDL CONNECTOR:
    To Display Trouble Codes:
    Run a wire or paper clip from Pin A to Pin B then turn the ignition on but do not start engine. The "Check Engine " light will flash in the following sequence: flash, pause, flash-flash, long pause flash, pause, flash-flash, long pause flash, pause, flash-flash, long pause. This is a code "12" which will always be there and tells that the diagnostic test is working. After this series of flashes and pauses any stored trouble codes will now flash. If you do not see the "12" flash three times, your diagnostic circuit is defective.
    Most vehicles will display stored trouble codes, then "12" again.
    TROUBLE CODES
    12. No reference pulses to Electronic Control Module (ECM). You will get this code when checking for error codes because the engine is not running.
    13. Oxygen sensor signal stays lean during warm engine cruise, your O2 sensor could be unplugged or faulty wire.
    14. High temperature indicated at engine coolant temp. sensor. Sensor could be unplugged or faulty wire.
    15. Low temperature indicated at engine coolant temp. sensor
    21. High voltage at throttle position sensor. Sensor could be unplugged.
    22. Low voltage at throttle position sensor
    23. Low temperature at manifold air temperature sensor
    24. Circuit fault in vehicle speed sensor
    25. High temperature at manifold air temperature sensor
    29. Fault in 4th gear switch
    32. Fault in exhaust gas recirculation valve diagnostic switch
    33. High voltage (low vacuum) at MAP sensor.
    34. Low voltage (high vacuum) at MAP sensor.
    41. Cylinder select error
    42. Fault at electronic spark timing circuit (sets when timing is set also, clear code and verify that it does not return.)
    43. Low voltage at electronic spark timing circuit
    44. Oxygen sensor lean
    45. Oxygen sensor rich
    46. Fault at vehicle anti-theft system
    51. PROM error
    52. Low voltage at oil temperature sensor
    53. High voltage at battery
    54. Low voltage at fuel pump OR Low voltage at Fuel pump relay
    55. Problem at Electronic Control Module (ECM) - ECM failure OR Serial bus error
    62. High voltage at oil temperature sensor
    CLEARING THE TROUBLE CODES
    Turn the key switch to the off position. To clear any trouble codes, disconnect the battery for 30 seconds or unplug the connectors to the ECM. If this is done at the battery, you may loose your preset stations on your stereo A better place to remove power is at the fuse.
    For a more informative diagnostic look at your system you will need a laptop computer, and ALDL cable and a free program called winALDL from here.
    http://winaldl.joby.se/
    For a more comprehesive program to look at trouble codes, record data and tune you chip all in one program check pout TunerPro RT:
    http://tunerpro.net/
    Good luck hope that helps.
    Compliments from dyeager535 for contributing these documents. Its a more complete fuel injection trouble codes and diagnostics. These are all in .pdf format so download and save them on your computer for future reference. Click on the link below, then after it downloads to your computer click on "File" then "Save As" and find a space on your computer. This way you only download once then have the file to use whenever you want even without an Internet connection.
    TBI Trouble Codes
    http://www.gearhead-efi.com/gearhead-efi/doc/TBIcodes.pdf
    TPI Trouble Codes
    http://www.gearhead-efi.com/gearhead-efi/doc/TPIcodes.pdf
    V6 Trouble Codes
    http://www.gearhead-efi.com/gearhead-efi/doc/v6codes.pdf
    dyeager535 likes this.
  2. 70jimmy
    70jimmy 3/4 ton status Premium Member GMOTM Winner
    Mar 3, 2000
    5,741
    48
    Released from Pueblo, told I belong in Southpark
    excellent THANKS!!!!:bow:
  3. lak2004
    lak2004 1/2 ton status
    Aug 31, 2006
    3,809
    Durango, CO
    Links at the bottow of top post no longer work, just thought Id let you know. Thanks for the info!
  4. eagle mark
    Nov 18, 2004
    3,289
    North Idaho!
    Just checked and they are downloading! :D
    They are .pdf file and take a minute to download. May be your computor, browser, operating system or no Adobe. Let me know if you guys are having issues!
  5. 84CUCV
    84CUCV 3/4 ton status
    Jul 1, 2002
    7,094
    NJ for now
    thanks ill try it
  6. eagle mark
    Nov 18, 2004
    3,289
    North Idaho!
    EDIT: Links above are now again hosted and correct!
  7. tRustyK5
    Jul 23, 2000
    35,576
    601
    E-town baby!
    Do you think you could put together the codes as a tech article? Maybe a couple of basic pics of the ALDL port? I can ask Steve if he'd consider adding it to the tech area off the home page...
    As many FI trucks as there are here it'd be a good resource, and not having it is kinda crazy.
    Rene
  8. eagle mark
    Nov 18, 2004
    3,289
    North Idaho!
    There's just to much there to not have the entire atricle posted. I'm sure the bandwidth is an issue but it is the most important thing to have/know if you have an EFI vehicle. If you know him please ask to read this...
  9. tRustyK5
    Jul 23, 2000
    35,576
    601
    E-town baby!
    OK, pm'd Steve. We'll see what he says. :waytogo:
    Rene
  10. eagle mark
    Nov 18, 2004
    3,289
    North Idaho!
    Forgot the TBI Codes were not stored on a server right now. For anyone needing them imediatly send me your email address. If you don't need them imediatly then just look back here and I should have them hosted this week somewhere.
  11. eagle mark
    Nov 18, 2004
    3,289
    North Idaho!
    First post links are fixed. :waytogo:
  12. FunHome
    FunHome Registered Member Premium Member
    Oct 3, 2005
    10
    Basehor, Kansas
    So after I jump from A to B with a paperclip and wait for the first sequence... Then what will it do?? Blink 13 times or whatever to show the codes??
  13. eagle mark
    Nov 18, 2004
    3,289
    North Idaho!
    From the first post...
  14. eagle mark
    Nov 18, 2004
    3,289
    North Idaho!
    I'm going to close this thread, if you need help please start a new thread for your rig. :waytogo:
Thread Status:
