tbi trouble
Discussion in 'The Injection Section' started by bscappell21, Mar 6, 2007.
  1. bscappell21
    bscappell21 Registered Member
    Mar 5, 2007
    7
    washington
    :confused: i have been reading all the trouble people have been having with tbi idleing and such and my problem does not quite match any of the others i think.
    after about 2 years of only driving once in a while i went and moved my blazer to a new place and it started up fine and idled just fine. when i was going down the road and the truck started having problems. at low idle to about half throttle it would try and die and such and if i babied it enough it would finally get going and WOT was just like normal. i thought well maybe bad gas or something like that. got it to her new home and went out the next day to start it and it took probably 20 revs to get it to start and the idle was horrid. then it would die. then i would start it and it would die. i checked the injector spray once i could get out of the truck fast enough to see before it died and it was spraying like normal but then it would just totally die. once it finally was able to hold its own i put it in gear and it died. so after just the right amount of TLC i got it to go down the road and it was fine as long as you either just leave it at low runing idle or WOT. any other time and at stop signs it just does not run right. i looked at the injectors while starting it from inside and it would spray fine and finally start after 5 seconds or so and then it would stumble and finally backfire with even a little flame. i thought i might just stop while i was ahead.
    i replaced the fuel pump relay and added some injector cleaner just in case it was something in the fuel system and made no difference. i can hear the fuel pump click on and all as well.
    any ideas? i really do not want to be like the rest of the people and start replacing every little thing to find out it was something totally different. i do not have the money to do that.
    thanks ,
    brandt
  2. dyeager535
    26,982
    191
    Sounds suspiciously like an EGR problem. You may need help, but keep the thing running at a steady (as steady as possible) RPM, and manually activate the EGR valve. You can press on it from underneath. Enough pressure should cause even worse running condition, and with enough pressure, it should stall the engine.
    Also test (with the engine off) that the EGR valve travels smoothly. It's somewhat imprecise, but again, depress it with your hand, and see if you can notice movement that isn't smooth.
  3. bscappell21
    Mar 5, 2007
    7
    washington
    where is the egr and what does it look like?
  4. dyeager535
    26,982
    191
    On the intake manifold somewhere, fairly large bell/mushroom shaped piece of metal. Should be one vacuum line running to it.
  5. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    Check the MAP sensor vacuum hose and electrical connector. This can cause your same symptoms. Make sure the vacuum hose is connceted and that it isn't plugged. Make sure the electrical connector is plugged in tightly.
  6. bscappell21
    Mar 5, 2007
    7
    washington
    so shouldn't there be a flash code comming up with these things not working?
  7. dyeager535
    26,982
    191
    Never rely on codes to indicate actual problems.
    Nice if you get one, but not always going to happen.
    Does your "check engine" light come on before you start the engine, with the key in "run"?
  8. bscappell21
    Mar 5, 2007
    7
    washington
    no, it does not. probably means no codes ehh? i am gonna check on the egr tomorrow and make sure there is no leaks anywhere.
  9. bscappell21
    Mar 5, 2007
    7
    washington
    so when i do this check, what results do i get if the egr is bad? the ones posted at the top?
  10. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    if your check engine light doesn't come on when the key is in the run position then you have a problem already. It should come on then once the engine is started it should go out and only come on again if a code is stored. Not always is a code stored like Dorian has already said.
  11. dyeager535
    26,982
    191
    Yep, first you need to fix the check engine light problem.
    More than likely the bulb is burned out, it was probably on constantly at some point, problem was never fixed, so the bulb just burnt out.
    Once you fix the bulb issue, then you can see if there are any codes. They tend to point you in a general direction, which never hurts.
    The "bulb test" is what you should see with the key in run, not start. If it fails that, either your ECM is bad, or the bulb is. Likely the bulb.
  12. chevyuser74
    chevyuser74 1/2 ton status
    Jun 19, 2006
    1,473
    Mukwonago, Wi
    please post up, if u find the problem, i would really like to know the cause
  13. 70jimmy
    70jimmy 3/4 ton status Premium Member GMOTM Winner
    Mar 3, 2000
    5,962
    252
    Released from Pueblo, told I belong in Southpark
    I second wanting to know the answer, I'm new to this FI stuff so trying to learn about it.
  14. DavidB
    DavidB 1/2 ton status
    Oct 8, 2001
    2,617
    El Centro, CA
    Yeah...me too.
