TBI-truck surging
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by FastEddy, Mar 11, 2001.
  1. FastEddy
    FastEddy 1/2 ton status
    Feb 3, 2001
    182
    southeast manitoba, canada
    I know this problem is not on my k-5 but figured I'd post it here as it's relevant....I have a 1987 chev 1ton dually with the TBI 454 and have a problem with it surging intermitently at all speeds....yes, I've changed the fuel filter....some days it's fine, some days it's terrible....help....it's my money maker...(Tow Truck)...thanks...ED
  2. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Have you had a fuel pressure gauge on it to see what the pump is doing? Probably isn't the cause but first good check to try. Injectors should also be checked. The FP regulator could also be causing it. Also would check for Vacuum leaks (listen, carb spray/propane,and cover up tests) and also would double check the EGR is functioning and not stuck or gummed up. Good Luck.
    1987 Chevy K5 Blazer- 350 TBI
  3. MudRebel350
    MudRebel350 1/2 ton status
    May 20, 2000
    324
    N.J.
    The TPS {throttle position sensor} could be on its way out. My first 87 K5 with a 305 would do that intermittently.
  4. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    It sounds like a fuel pump or ignition module. My module has gone out twice and both times it ws rather sudden. At least you can tow yourself home[​IMG]
    90K5
