TBI upgrades
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by smack, Nov 1, 2001.
  1. smack
    smack 1/2 ton status
    Feb 24, 2000
    277
    Colorado
    Hello all!
    I'm trying to squeeze a little more outta my stock but new 350 for towing reasons. Right now I've got edelbrock headers and a K&N filter. Was thinking about forking down money on the Holley TBI, a spacer, a street-chip and maybe roller rockers.
    Any thoughts on these four??
    '87 Jimmy
  2. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    Keep the factory TBI, invest in some vortec heads, intake, a cam, the spacer, and a chip.
    '85 K5 : Run it til it breaks, then fix it and go again!
  3. smack
    Feb 24, 2000
    277
    Colorado
    Well, i don't wanna touch the heads 'cos the motor is a brand new chevy motor with a warranty. I'd consider changing the intake but even that makes me nervous. I was dying to get the crate motor but time and finances didn't allow, and seeing how my wife and I were buying a house I did the responsible (stupid) thing and bought the stock motor so I could get the good warranty.
    '87 Jimmy
  4. smack
    Feb 24, 2000
    277
    Colorado
    Does anyone know about changing over to roller rockers with a higher ratio and the possible problems with that??
    '87 Jimmy
  5. 1990K5
    1990K5 1/2 ton status
    Nov 6, 2000
    460
    LITTLETON CO.
    the holly tbi absolutely positivly SUCKS! go with a computer compatable cam, they are about $130 and will get you an honest 25hp.
  6. JunkYardCrawler
    JunkYardCrawler 1/2 ton status
    Sep 9, 2000
    575
    Tucson, AZ
    they only thing i know aobut roller rockers is that i have blown 2 sets of them. and none of the stock ones. but one of them was a bad batch and i not sure about the other. didn't care just wanted the stock back in.
    Going nowhere everybody is a Moto Psycho
    Got my wheels in motion and i got a path to beat
  7. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Check out these guys:link=http://coloradok5.com/gallery/Thunders-Blaze
    <font color=blue>NEVADA: Where the pavement ends, and the West begins.</font color=blue>
  8. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    When your towing, do you need help getting the load rolling ? or on the freeway with low rpm's(2000 rpm's ?) ?
  9. smack
    Feb 24, 2000
    277
    Colorado
    Hey thunder, what upgrades do you recommend and how expensive?
    '87 Jimmy
  10. smack
    Feb 24, 2000
    277
    Colorado
    to Executioner:
    Both really, but mostly I'm looking for already moving power -- like in third gear already moving. I've got a 4-speed so from the start it's not too bad but I have to red-line it between gears otherwise my rpms drop too much.
    '87 Jimmy
  11. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    what size tires and gears are you running? Regearing is usually one of the most cost effective things you can do.
    90K5
  12. 502Burban
    502Burban 1/2 ton status
    Jun 8, 2001
    379
    Southern California
    You can run the 1.6 ratio rockers, which will give you more lift. You can do the math to see the difference it will get you. The stock ratio is 1.5:1. However, this won't change your cam duration, or make huge improvements in power.
    Possible problem areas to watch for:
    1) Valve spring bind-up. The extra lift is usually only a problem if you are running a high-lift cam to begin with.
    2) Valve to piston clearance. Again, only likely to be a problem with a higher lift cam.
    3) Reliabiliity. This shouldn't be an issue unless you try to save some money and purchase lesser-quality rockers. If you stick to Crane, CompCams, or other name brands, you should be safe. I have run Crane roller rockers in small and big block Chevys and small Furds, too. All on the street with no problems at all. Some will tell you that the trunnion bearing (the large needle bearing at the stud) will need to be rebuilt after 30-50k miles, but I don't see that as a big drawback, myself.
    Having said all this, I think that you could spend your $250 better, elsewhere, if you are looking for power increases. Just my $. 02, though.
    Robb
    '73 GMC Suburban - 502DFI
    <a target="_blank" href=http://community.webshots.com/user/robbrj>community.webshots.com/user/robbrj</a>
  13. smack
    Feb 24, 2000
    277
    Colorado
    Right now I've got 31's on it but as soon as they go I'm gonna put 33's on. I've got 3.73 gears, a SM465 and a 208 case.
    '87 Jimmy
  14. smack
    Feb 24, 2000
    277
    Colorado
    Yeah, doesn't sound like roller rockers are all that worth it.
    Hmm... can somebody sell me a cheap super charger!!!????
    '87 Jimmy
  15. smack
    Feb 24, 2000
    277
    Colorado
    Maybe someone out there wants to trade their 330 crate motor for a new GM motor with a warranty? Hmmm? Hmmm? Hmmm???
    '87 Jimmy
  16. Executioner
    Feb 22, 2000
    1,530
    You heard of Nitride Oxide(NO2), if your at 2000 rpms you can slowly inject, small amounts !
  17. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    I found some pretty good TBI mods over on the thirdgen.org site. These are free mods, you just need a dremmel or something like it.
    Check them out:
    <a target="_blank" href=http://www.thirdgen.org/newdesign/tech/ultimatetbi.shtml>Ultimate TBI Mods</a>
    <a target="_blank" href=http://www.thirdgen.org/newdesign/tech/ultimatetbi2.shtml>Ultimate TBI Mods, Part 2</a>
    Apparently, GM left a lot of casting material inside their TBI units and it restricts the flow quite a bit. I have read many writeups from people who have done this, and they say it makes quite a difference.
    Good luck,
    Thomas.
    -- '84 1-Ton Blazer --
    When the goin' gets tough,
    the tough go 1-Ton [​IMG]
  18. smack
    Feb 24, 2000
    277
    Colorado
    Thanks, ever tried any of these??? I wonder if those dremel mods are basically what Turbo City sells..
    '87 Jimmy
  19. smack
    Feb 24, 2000
    277
    Colorado
    How well does NOx work with a TBI??
    '87 Jimmy
  20. Executioner
    Feb 22, 2000
    1,530
    Works real good. I have seen(been there) dyno pulls from 2-3K rpms, with about 40-90 HP increase
    and almost 100 lbs./ft. of additional Torque. Also road with a guy pulling a sail boat that uses NO2 to supplement
    pulling chores when the engine was at 2200 rpms in final drive, and it went right up the mountain pass.
