TBI v/s carb, engine buildup specs question..
Discussion in 'The Garage' started by uglychevyZZ4, Sep 18, 2002.
  1. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    I am trying to find out the difference in the engine specs for a engine that is tbi. mine WAS carb, but no more. i want to have the correct specs so there are no emc gaps in performance. do i just need a post 87 spec or what?
  2. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color="blue">Why not just reprogram the ECM to compensate for your engine?
  3. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    Well id rather build it right than hack the ecm /forums/images/icons/wink.gif I just need to know if the rod length and pistins etc.. are the same or different.
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The engine internals are the same, except for the cam. /forums/images/icons/cool.gif
  5. Chris Demartini
    2,406
    Dumont NJ 07628
  6. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    Hacking the ECM is fun
    [/ QUOTE ] *takes away tools*
    you bad bad boy
  7. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    [/ QUOTE ] ok, im finding that the internals arent, especially the pistons, seems that they are dished for lower compression /forums/images/icons/confused.gif /forums/images/icons/confused.gif
  8. mitymouse
    mitymouse Registered Member
    Sep 23, 2002
    27
    elkhart,IN.
    I guess my question is are you going through this block or what,If so do a set of forged flat tops even a cheap set of trw are better then stock. The rods are 5.7 there were some differances in some of the rods from what I understand,I always replace with a luniti rod Even the cheaper street race rods hold up great,I broke a stock rod once and wiped out almost an entire motor,never again....
  9. mitymouse
    Sep 23, 2002
    27
    elkhart,IN.
    comp cams can custom grind a cam for your tbi set up that will work with in the ecms peramitors, precision turbo and countless other companies can most likely reformat your ecm or cut you a chip just for your specs..
    Hope I am helping am unsure what info you are actualy looking for
  10. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    All the stock truck 454's had very low compression ratios, at least in the 80's and '90's. Somewhere around 8.2-8.5:1. /forums/images/icons/frown.gif
  11. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    but it isnt a 454 /forums/images/icons/wink.gif
  12. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    For some reason I thought you were playing with a 454! /forums/images/icons/confused.gif
