TBI VRS TPI
Discussion in 'The Garage' started by tgswillys, Oct 19, 2003.
  1. tgswillys
    tgswillys Registered Member
    Sep 21, 2003
    38
    utah
    HEY GUYS IM ABOUT TO DO A HEART TRANSPLANT IN MY WILLYS AND IM HAVING A HARD TIME DECIDING WHICH WAY TO GO /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif I HAVE ACCESS TO A 350 TBI WITH HARNESS AND A 305 TPI WITH HARNESS. I'VE HEARD THAT WITH THE TPI I WILL HAVE MASS TOP END BUT LACK ON THE LOW END AND IM GRANNY GEAR KINDA GUY. ANY INPUT ON THE DIFFRENCE??
  2. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    TPI was designed for lots of low end torque not top end.
  3. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    Heres a good link on TBI and TPI.
    The simple setup is TBI.
    TBI and TPI
  4. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    If you are going to stay stock or mildly modified I perfer TBI in a truck for its simplicity and lower cost.
    Both TBI and TPI build good torque.
    If you are going to modify the engine with a hotter Cam and more air flow then I would go with TPI. Because they are Mass Air flow based system they tolerate engine mods better than TBI systems.
  5. dyeager535
    26,976
    Sounds like a great reason to put the TPI on the 350, and have the best of both worlds. /forums/images/graemlins/smile.gif
    TPI as it came from the factory was not a high RPM powerhouse. The long runners limit upper end horsepower, but torque is very impressive.
