TBI w/ open air filter
Discussion in 'The Garage' started by IDGMC, May 10, 2005.
  1. IDGMC
    IDGMC 1/2 ton status
    Feb 18, 2000
    150
    Idaho
    I installed a K&N air filter with the chrome housing that I had laying around on my 91 k5 with a 350/tbi. This morning when I started, I heard a loud sucking air sound. It seemed to go away after the truck warmed up. Is there any problem with running this type of airfilter on this set up? should I put the old metal housing back on?
    thanks
  2. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    I have the xtreme on my 89 no problems :cool1:
  3. NEplainsman
    NEplainsman Registered Member
    Dec 11, 2004
    6
    casper,wyoming
    the loud noise was the idle air control-normal sound,and no it should'nt hurt to run an open element filter but who want's hot underhood air?it does'nt build horsepower,your stock airbox with a tube sucking up outside air will get you more power-just wont look as cool!
  4. IDGMC
    Feb 18, 2000
    150
    Idaho
    So I should sell this one to a buddy and just put in a k&n that will fit inside my stock housing
  5. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Yup, IAC sound, no worries.
    Hey Blazinid, what size air cleaner are you running? I had a problem finding the housing that would clear all the stuff mounted on the intake. I wound up using a 10" diameter filter and housing.
  6. IDGMC
    Feb 18, 2000
    150
    Idaho
    I think its 14" X 6" Its pretty damn big. I ordered it from summit about 5 years ago and its been in storage. Its the k&n filter with upper and lower chrome housing. sits just fine and clears everthing.
  7. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Ok, cool, thanks. I'll look over at summit, and see what might be different.
  8. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    I'm kinda late on this, but I run a K&N open element deal on my DD for the hell of it. It does the same thing, kind of a hissing sound until it warms up. Sounds dumb but I actually like it, reminds me not to hammer on it when it's cold.
  9. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    I had a slightly different case... had to install a 14x3" open filter on mine to eliminate hissing. I put a decent cam in the engine, and it was literally sucking air through the intake. the 14x3 is on until i can figure out a different snorkel/tube system to get a decent amount of air to the engine. my big worry about the open element is water and mud :(
  10. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    I just put a 4" one on mine and it 'sucks' like hell too! I'm only putting it on there 'till I make/get hold of a sealed system. It's on a TBI conversion I put into my '78.
  11. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I would go back to the stock housing / cold air intake. and put a K&N in that. The stock setup flows more than enough CFM for a stock TB. You will acually loose power with an open element air cleaner with TBI.
    TBI likes cold outside air, not hot air from the engine compartment. More noise does not equal more power.
  12. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
    they also cost 3 times as much.
    I run a k and n filter with the chrome k and n extreme lid and noticed a slight increase in throttle response when i installed it.
