TBI woes
Discussion in 'The Garage' started by clarkjw24, Oct 15, 2005.
  1. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Well I can't figure this thing out. Its still cranks and idles but dies once its put in gear. Also has a backfire. I've noticed that the pass injector is wet around the plug were as the drivers side is dry. Both seem to be pulsing the same into the TB. Its not throwing any codes now. Could someone help me please. Could the ecm be bad or maybe the tb regulator?
    I have replaced the following in the last couple of weeks.
    Plugs
    Wires
    Coil
    Air Idle controll
    Map
    Fuel filter
    Fuel pump
    New sock
    Distributer Cap
    Rotor button
    O2 sensor
  2. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    sounds like maybe the only thing left is the regulator.
    ryan
  3. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Where do I get one? How hard is it to change and what do they cost? Thanks
  4. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    might have one in stock here at the stealership.
    give me a minute to check.
    ryan
  5. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    nope dont have on in stock.
    gm # 17112399
    cost (employee) about $74 plus tax.
    is very easy to change.
    ryan
  6. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    :eek1:
    I believe I'll just get another complete used Throttle body. Thanks ryan. Got a one coming from a guy on here.
  7. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    yeah the aftermarket adjustable ones are cheaper than the gm ones.
    ryan
  8. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    have you checked the timing?
    just wondering
    ryan
  9. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Yeah I've got a digital T.L. and its set exactly where I had before when it was running right.
  10. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    Have you checked the fuel pressure? TBI should read around 12 to 15 PSI when running, and not loose any more than a pound or two under acceleration, low fuel pressure causes all sorts of weird problems.
  11. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    I didn't have a way to check the pressure thats why I just bought a new fuel pump and checked all the lines for kinks and bends.
