Tbi ?
Discussion in 'The Garage' started by stayaway, Aug 1, 2005.
  1. stayaway
    stayaway Registered Member
    Aug 1, 2005
    59
    georgia
    hello all I have ? about tbi just built my motor for a 87 k5 and but a small cam in 280duration 486lift with the stock heads 40over with flat tops the prob is it will not idle right have the same motor in my 87iroc and had to have mass air flow recaled but it is tuneport is there a map sensor that I can buy or some way to fool it I did drill a hole in the header and welded a place for the o2 sensor any help would be nice thanx
  2. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    What is the lobe seperation on that cam. If it is less than 114 or 112 I think it will not build sufficient vacuum in the manifold for the MAP sensor. I believe this is the issue. If I am wrong please let me know guys.
    Ira
  3. Codeman96
    Codeman96 1/2 ton status
    Jan 22, 2003
    184
    Southeast Mo.
    Something with a duration in the 280s is going to have a pretty good chop anyway. A straight 280 Comp Magnum is what I have in my '79 Capri drag car and it sounds nasty at idle.
  4. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    yur running too much duration for the stock chip to handle. You will need a new chip burned for your cam. You will also have to take into concideration what your compression ratio is.
    The stock chip wont run cams much over 212 Dur at .050 (260 total dur)
    LSA 212
    Lifts up to and around 480 will work
    Compression ratio up around 9.2 to 1
  5. LongIslander26
    LongIslander26 1/2 ton status
    Jun 25, 2005
    256
    Park County, Montana
    Crummy idle
    You can run a cam with those specs, you just need a wider LSA, so your overlap isn't so much, and the engine will produce decent vaccuum. Generally, an over lap angle of 45 degrees or less is what you're shooting for. Check the spec card that came with the cam, otherwise, you'll need to get a chip burned for your PCM.
  6. stayaway
    Aug 1, 2005
    59
    georgia
    Thanx you guys for all the help will be getting a new chip next week thanx again
