  1. KMH87K5
    KMH87K5 Registered Member
    Jan 23, 2002
    13
    Bethlehem, Pennsylvania
    Is the "big ring" on top of the tbi a spacer? Mine is loose. Will this cause the truck to run bad? Is it put on with a gasket. How should I replace it. Any help would be appreciated.
  2. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    The ring on top is just a spacer to keep the air cleaner from contacting the TBI. It doesn't use a gasket or anything and if it is loose it will not affect your performance. You can tighten it by screwing down the wingnut on top of the aircleaner assembly. A throttle body spacer goes between the throttle body and the intake manifold.
  3. KMH87K5
    Jan 23, 2002
    13
    Thanks for clearing that up for me!
