TC lockup vacuum switch ( i may have asked this before)
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by greg83k5, Mar 21, 2002.
  1. greg83k5
    greg83k5 1/2 ton status
    Nov 2, 2001
    230
    space sity houston, texas
    where is that little booger supposed to be hooked up to?
    greg
  2. Jay73K20
    Jay73K20 Registered Member
    Mar 4, 2002
    67
    The vacuum side should be hooked up to manifold vacuum. That means pretty much any port as long as it isn't ported vacuum. Manifold vacuum is the vacuum that is felt in the manifold which is underneath the throttle blades and ported vacuum is felt right above the throttle blades. So at idle you will have more vacuum under the throttle blades and little to no vacuum above them. The electrical side is tied into the brake switch and +12VDC. Here is a simple wiring diagram that will work http://www.700r4.com/Tech/TCC/TccEnergizedBosch.pdf
