TC TH400 - thread size?
Discussion in 'The Garage' started by dieselponyexpress, Jun 16, 2005.
  1. dieselponyexpress
    dieselponyexpress 1/2 ton status
    Jan 26, 2004
    220
    Germany
    Searching for new bolts for my th400 converter (behind a 6.2l diesel), it seems to me a 10mm-1.5 would fit.
    Well, not exactly, so my questions.
    This is the same for both of my converters (old & new).
    I know the 6.2 motor does have a lot of metric threads but never heard of a GM tc with other than standard size threads, like 3/8-16.
    In a parts catalog I found bolts for a H1 (with the old th400) with metrich threads. :confused:
    I had lots of problems in the past with loose tc bolts and broken flexplates, so I want to go for sure this time.
    What do you guys use?
    Walter
  2. gambit420s
    gambit420s 1/2 ton status
    May 17, 2005
    294
    KnoxVegas, Tennessee
    ive got 7/16-20tpi in a couple converters i've got laying around; 80 caddy, 80 c-30, 89 V-2500, 72 98, but i think 700's 200's 4l60(e) and 4l80e's are M10x1.5
  3. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    All your info and it doesn't even cover his application. :doah:
    Actually, i do think it is 10 x 1.5mm though. :thumb:
  4. gambit420s
    May 17, 2005
    294
    which is exactly why i put it there, i didnt know if the diesel t/c was different as i am not lucky enough to own one. thus the statement about the metric size being correct for other gm tranny's
  5. dieselponyexpress
    Jan 26, 2004
    220
    Germany
    Good Info - Thanks a lot gambit & 4x4high :)
    Not too tricky finding a M10x1.5 here in germany ;)
    Do you think I should go with a spring washer or take bolts with a larger head section (like a built in washer - don't know the term in your language, sorry for that)?
    Thanks again.
    Walter
  6. dieselponyexpress
    Jan 26, 2004
    220
    Germany
  7. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    That would be a flange head bolt, that is what I would use with a dab of blue loc-tite.
