Tcase doubler
Discussion in 'OffRoad Design' started by cegusman, Jul 15, 2002.
  1. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    What is requied to install a doubler behind a 700r4, what 203 for what trans, and what 205 for what trans, would I need a different output shaft on the trans? Or iws this not possible? Are you able to still use the pto option?
  2. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Taken from http://www.offroaddesign.com/catalog/doubler.htm
    GM TH700 R4 / 4L60E Automatic Transmission:
    The TH700 has the same bolt pattern on the back of the transmission as the TH350 and uses a 27 spline output shaft. Since the TH700 only came with the NP208 or later alum t-cases, it's shaft stickout is a little over 2" in factory form. One difference to be aware of is that the TH700 uses 4 metric bolts to secure the adapter to the transmission case.
    There are two ways to bolt to the NP203. They are very similar to the TH350 mounting mentioned above.
    1: replace the output shaft in the TH700 with an aftermarket output that sticks out of the case by about 7/8". This makes the output identical to the TH350 and you use a TH350 version NP203 with the 27 spline input and a TH350 to NP203 factory 1" thick adapter plate. This is the shortest method. The output shaft cost is $160 and it is available from ORD.
    2: use the factory TH700 output shaft and the factory TH700 to NP208 adapter housing with a TH350 version NP203. You will have to re-drill and tap holes in the NP203 gearbox to be able to bolt it to the original NP208 adapter housing. You may also have to do minor machine work on the input bearing retainer on the NP203.
  3. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    There's more info on this on our site and available if you search here but this is it in a nutshell:
    Replace output shaft in TH700, we carry the part, it's $160.00
    Use TH350 version NP203 with factory 350 to 203 adapter plate.
    Use TH400 version 205 from early 80's. Or modify another 205 to match this spec.
    You can still use the PTO on the 203 and the 205, depending on the clearance around the unit, etc. You may also need some case mods on the 203 to run the PTO since we use the PTO cover for the oil fill with our kit. Basically you'll need to add oil somewhere else.
  4. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Is the output shaft the same one used to connect the 205 to the 700r4?
  5. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Yup, as long as you're using the TH350 to NP205 factory adapter housing.
