Tcase drop questions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Leper, Aug 15, 2005.
  1. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Hey all,
    I am dropping my tcase 1" with some box tubing. Is there anything I will need to lengthen/shorten for this? Just looking for any problems or concerns associated with doing this job before I start.
    TIA
    Leper
    BTW 91 Blazer 350/700/241, ft 4" springs and zerorate, rear ORD shackle flip with zero rate.
  2. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Nope, really simple job.
    John
  3. Leper
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    That's what I wanted to hear!!!
  4. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    I had to adjust my t-case linkage a little, but other than that, no problems at all.
    Rick
  5. BlitzK5
    BlitzK5 1/2 ton status
    Jul 29, 2005
    288
    Sherwood Park, Alberta, Canada
    Good question. I was also thinking of doing this with my NP208. But I was wondering would you have to adjust your engine mounts to do this?
  6. perp
    perp 1/2 ton status
    Jul 14, 2005
    569
    Chandler AZ
    motor mounts will flex plenty for that. no adjustment required.
  7. BlitzK5
    Jul 29, 2005
    288
    right on thanks
  8. Leper
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    I came across a site that says not to dop the tcase because of the way it makes the engine sit. Anyone ever have a problem with a drop or know a detailed reason why not to?
  9. onlychevy6
    onlychevy6 1/2 ton status
    Mar 29, 2003
    1,293
    Hockley, Texas
    on my old 78 blazer i had a 6" suspention lift and kept breaking the rear drive shaft. I was told by the manufacture of the drive shaft to drop my t-case 1 inch and add 6 degree shims in the rear. After i did that. I had better highway driving, and no breakage. I also ran 35" BFG All Terrains with 4.10 gears
  10. btolenti
    btolenti 1/2 ton status
    Sep 28, 2003
    644
    Gilroy, CA
    You could run into problems with the distributor being too close or actually hitting the firewall.....especially if you have the large cap HEI.
    My 1" drop worked fine on my 86 (with the large cap HEI).
  11. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    why not just use the factory 1" spacers? thats what most people do.
    another problem with dropping the T/C is that it puts added stress on the frame where the crossmember mounts. maybe if you used box tubing it would be a little stronger than the factory spacers.ive seen pics of the bolts tearing loose @ the frame from dropped crossmembers.
  12. bigjbear
    Feb 18, 2000
    13,966
    448
    Marietta GA
    That is exactly why. Those stock spacers put too much stress on the frame and cross member. Using tube or something with a larger diameter works a lot better.
    On a side note, that kind of a backwards solution. You are taking away the lift you paid for. Just my experiences, take it as you will.
  13. 81jimmyslt
    81jimmyslt 1/2 ton status
    Jun 5, 2003
    1,643
    So Lake Tahoe (Rubicon), CA
    Yes. When I dropped mine with home made spaces it made the angle of the front shaft worse and it contacting the crossmember slighty. You will also most likely have to adjust your tcase linkage. And your entire drivetrain now rests on an angle, everything shifted harder.
    I took them out.
  14. Leper
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Thats enough info for me. Not gonna do it. Anyone want to buy some 1" tubing predrilled for dropping a tcase?
  15. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    '85 Sub+2", I raised the "W" by taking out the 1" spacers; for more break-over, no problems front or rear. :burb:
  16. bigjbear
    Feb 18, 2000
    13,966
    448
    Marietta GA
    On adjusting the x-fer case linkage: that only applies to the 208/241. The 203/205 do not mount to the floor.
