Tcase Drop?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Hossbaby50, Nov 29, 2001.
  1. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I have a small vibe in the rear end, and I am about to add the ORD 1" add a leaf. Is it better to drop the tcase, or shim the pinion? I would like to avoid dropping the tcase so I don't loose ground clearence. Oh ya, I have a 21/2" lift (addaleaf) which has sagged to about 2"s. Any input helps.
    What degree shim, or how far should I drop the tcase. Any input helps. Thanks
    My Chevy isn't broken, its just out of gas.
  2. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I would start out by swapping the T-Case mount - you'd be amazed at the difference $20 can make, and if that didn't work, go ahead and take the case down ½" or so. With a decent mount, mine runs vibe free with 4" on the rear and the case in the OEM position, so I'd say start with the quick and easy before fooling with shimming it.
    ......And knowing is half the battle
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  3. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    The rear mount is pretty new (about a year old). Do I need to go buy a tcase drop kit, or can I just go to the hardware store, and get some metal spacers and longer grade eight bolts? Thanks
    Harley
  4. FatBoyBlazer
    FatBoyBlazer 1/2 ton status
    Feb 22, 2001
    1,508
    Worcester, MA
    you can drop it by useing the factory spacers. put a floor jack under it, take the 4 bolts out and the 4 spacers(look like a 1inch long washer) put them bettween the croosmember and the frame and you should be all set i did it and it solved my problem of the vibrating
    hola
  5. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Thanks for the info. That was what I was hoping to here. Thanks again.
    Harley
