tcase meets header
Discussion in 'The Garage' started by shaun, Sep 15, 2004.
  1. shaun
    shaun 1/2 ton status
    Apr 22, 2003
    745
    So I clocked my t case all the way up, (I love how this looks) now my long tube headers hit my front driveline. So can I have the exhaust shop shorten the header or will this cause major issues to the header. I dont want to buy shorties (it is a sbc 350) because I am swapping in a 500 within a couple months (its expensive to build). What do you guys recommend?
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Stuff a two by four up there and bend it over to the frame some. I had this problem on my old Small block. I bent it over and ground on the flange some to clear it out.
  3. shaun
    Apr 22, 2003
    745
    By bending it will this affect how it sits on the head. As in causing a leak?
  4. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i had the same problem, i heated the header up and bent it over, but that didn't last long, it bent back
    here is what mine looked before the lift.
    after the lift i only had a problem with it hitting the exhaust tube not the header.
    you can see it here.
    it rubbed on th tube for a little bit, but it made its own clearance.
    what did you do for a crossmember?
    just wait till you get to use it /forums/images/graemlins/deal.gif its unbelievable on what you can go through now. /forums/images/graemlins/peace.gif /forums/images/graemlins/peace.gif
  5. shaun
    Apr 22, 2003
    745
    I still have the stock crossmember for now I am trying to figute out what to do about a crossmember. I am thinking a piece of 1/4 inch bolted inside the frame with the mount bolted to that. Making the underside look like this
    O-----O instead of like this O--v--O /forums/images/graemlins/thumb.gif
