Tcase Question Its a good one I think
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Monster, Jul 24, 2002.
  1. Monster
    Monster Registered Member
    Jun 14, 2002
    68
    New Jersey Warren county
    My 700R4 Died on me a couple of days ago and it is being rebuilt . But the guys working on it discoverd my T-case is filled with 90 weight gear oil. WHY?????????? Also my 86 K5 Blazer came from Arizona Maybe out there they do that for a reason. One more thing my rear end has a gear ratio of 3.07 Does this sound correct. /forums/images/icons/grin.gif
  2. Batmanjr
    Batmanjr 1/2 ton status
    Mar 23, 2001
    1,537
    Copperas Cove, Texas
    Yeah, my wife's 87 had 3:07 before I changed to 4:10s! What transfer do you have? If it's a 205? That's what it's supposed to be!!!! If it's a 208, get that sh**** out of there!
  3. Monster
    Jun 14, 2002
    68
    Sounds good I have to see what t case it is
  4. BLUESMAN
    BLUESMAN 1/2 ton status
    Oct 3, 2001
    951
    Phoenix(but it\'s a dry heat...like an oven!)AZ.
    Seriously doubt that's it an 205 unless someone swapped it in.The 205 never came factory behind an TH700.More than likely it's an NP208,you have an '86 right?No reason to have gear oil in it.No we guys/gals don't put gear oil here in Az.Unless it could be a Northen Az truck,but I've never heard of anyone doing that.Hey I could be wrong!In any case fill it with ATF if it is an NP208.
  5. Grim-Reaper
    7,385
    Atlanta
    Your 3.07 gears and 35's are why your Transmission is smoked. You need to get 4.56 gears. Your over working the tranny. It's over heating and you cooked it. You could have regeard for what that tranny rebuild is costing you. That poor tranny is feeling like your dragging a full size bronco behind it every where your going. If you don't have a AUX cooler you need to get one. Heat is what kills tranny's You keep them cool they will last a lot longer. Talk to the tranny shop, they will back up everything.
