tcase replacement options?
Discussion in 'The Garage' started by ohio k-5, Oct 4, 2005.
  1. ohio k-5
    ohio k-5 Newbie
    Mar 29, 2005
    marion, ohio
    this is not a k5 question, but i just obtained a 92 k3500. it has a 350 4l80e and a borg warner 4401 that came with it. however the tcase has a 6 inch hole in hte case where someone dropped it.
    i need to find out what all is compatable with this setup? i've been told the borg is very rare and i probly won't find one. i think it has 2 electric connection on it, if i remember right.
    any help will be great
    thanks
  2. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    if I remember correctly there were 3 different BW TCs used. Your tranny should be like a th400 w/ has a 32 spline output, maybe a NV241 would work. I'm not sure about the bolt pattern but you'd probably need the adapter for the 241 vice the BW adapter. It would all come down to the output shaft of the tranny.
  3. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    The BW4401 isn't too bad to find. Its the 1370 and 4470 that are worse - they are the 11k GVW models and have a magnetic engagement clutch iirc.
    An NP241 will bolt onto the same adapter... but now you have a slip-yoke t-case.
