Tcase/tranny issue, I think???? Please read and help
Discussion in 'The Garage' started by TexasBlazerBoy, Mar 12, 2007.
  1. TexasBlazerBoy
    TexasBlazerBoy 1/2 ton status
    Oct 10, 2005
    1,674
    North Texas
    Details of my Blazer are in my sig.
    Just to let everyone know. I got my 4" lift done 3-5-07 and new 35" tires 3-9-07.
    Sorry if this is hard to follow.
    I broke one of my front ujoints on my front drive shaft this weekend. The one near the tcase.:mad:
    I removed the front drive shaft.:D
    I get back in my blazer and put the tcase into High(road gear for a 203), I then put my tranny into D. No go? :mad:
    So, I put the tranny back in P. Then move the tcase into High Loc, then move the tranny into D. No go.:mad:
    Then I put the tranny back into P. Then move the tcase to Lo and the tranny into D. No go.:mad:
    Then I put the tranny back into P. Then move the tcase to Lo Loc and then the tranny into D. YES:D finally it drives, except I have 80 miles to get home. NOT GOOD.:doah:
    Why will the tranny/tcase not work while in High?:confused:
    Well now I am in Lo loc, with tranny in reverse, I back up about 75 yards.
    Now, I try it again with the tranny in P and move the tcase to High(road gear)and then the tranny to D. FINALLY THE TCASE IS IN HIGH AND THE TRANNY IS IN D and I can go forward.:D
    New problem, I can accelerate and drive until I left off the throtle and then my "driveline goes away":mad: :crazy: , no forward movement. To fix this I have to put the tranny into N, and lower the tcase in to High loc then it works and I can move the tcase back up to High.
    If this is to hard to read sorry. :(
    Any help would be great.:bow:
    Larry
  2. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    T-case has a diff in it. If your front shaft is out and you don't have a part time kit you will have to run it in Hi-Loc or your front T-case output will be the path of least resistance and no power will go to the rear.
  3. TexasBlazerBoy
    Oct 10, 2005
    1,674
    North Texas
    So, I don't have a mechanical failure with my tcase or tranny? :confused:
    Are the ujoints hard to change?
  4. resurrected_jimmy
    May 23, 2005
    2,241
    Your trans/T-case is probably fine. Make sure that the linkage is adjusted properly and moving freely. It sounds to me like your T-case was not locking in Hi-Loc completely. Drive shaft u-joints are not hard to change. Acouple of big sockets and abench vise make a good enough press to pop the old one out and the new one in.
  5. TexasBlazerBoy
    Oct 10, 2005
    1,674
    North Texas
