tcase/u joint/rear driveshaft=broken
Discussion in 'The Garage' started by Propayne, Mar 23, 2006.
  1. Propayne
    Propayne Registered Member
    Nov 27, 2005
    67
    San Angelo, TX
    now i know this is a common problem. and i didnt know the signs of a ujoint about to go out(vibrating and such) but does anyone know the name of the arm that comes out the back of the tcase and connects to the rear driveshaft . this is probably a stupid question...but can anyone show me a picture of what one looks like up close where it connects to the joint?
  2. stockk5
    Apr 13, 2004
    2,035
    71
    Cromwell, CT
    well if u have a 208 transfer case.. its called a slip yoke...
    this is what it looks like... at a bad angle..
  3. Propayne
    Nov 27, 2005
    67
    San Angelo, TX
    are there supposed to be bolts that hold the slip yoke to the u joints and rear drive shaft?
  4. Citizen Rider
    Citizen Rider 1/2 ton status
    May 5, 2005
    1,415
    Plano, Texas
    On a slip yolk both caps are pressed into the peices. What year is your vehicle?
  5. Propayne
    Nov 27, 2005
    67
    San Angelo, TX
    87 blazer, i do not know how to take out the old u joint or put new ones in...but i can search for that material. what size joints would i need for this
  6. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    My guess, 1310's with inside clips.
  7. Propayne
    Nov 27, 2005
    67
    San Angelo, TX
    ok, last question before i tackle this thing(had mild case of food poisoning yesterday so couldnt work on it). when the drive shaft came off, the slip yoke slithered its way out of the tcase....im pretty sure my guess was correct but is the pinkish fluid that came out Transmission fluid? if it is, can i just pour some more in the spot under the hood, or is there a certain place to pour it in the tcase
  8. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    there is a fill plug
  9. Propayne
    Nov 27, 2005
    67
    San Angelo, TX
    thanks chaddy
  10. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Some tcases use trans fluid, some use oil. The tcase has a fill plug that is visable from the dshaft area. Where in Tx are you?
  11. Propayne
    Nov 27, 2005
    67
    San Angelo, TX
    im in san angelo, my mom lives in dallas (east, rowlett)
    im pretty sure it was trans fluid because it was bright red/pink
  12. Propayne
    Nov 27, 2005
    67
    San Angelo, TX
    this would be easier, but i cant get the old bastard U joint off
  13. Leper
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Are you in Rowlett now?? Someone from the Texas crew can probably swing by.
  14. Propayne
    Nov 27, 2005
    67
    San Angelo, TX
    no, unfortunately im not in Rowlett....im in San angelo. but if yall are ever in San angelo or near it let me know. my friend is getting a clamp so ill hopefully be able to get the rest of the dshaft off.
  15. Leper
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    A quick answer is to pull the retaining clip off of the ujoint and, using a socket, hammer out the ujoint cap, then do the same for the other side.
    Turn your Private message settings to "on".
  16. Propayne
    Nov 27, 2005
    67
    San Angelo, TX
    i dont know where tje PM settings are, i looked in all of my options(sorry im a complete newbie at vehicles and forums).
    it would be better to completely take off the entire driveshaft than to just try and put the ujoint back onto the yoke? also, all of these sites talk about not knocking the needle bearings out. i must not have done this because i havent seen any fall out or anything different in the bearings and joints.
  17. Leper
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    I've never seen anyone do it with the dshaft in. Be sure to block the wheels and set the parking brake. I sent you an email with my phone #.
  18. Propayne
    Nov 27, 2005
    67
    San Angelo, TX
    thank you sir. ive already got the brake on and wheels blocked.
    if you havent noticed by now, im 16 years old, so my tools and knowledge is limited, but that you for your help.
  19. goldwing2000
    goldwing2000 Guest
    Non-paying users can neither send nor receive private messages.
  20. Propayne
    Nov 27, 2005
    67
    San Angelo, TX
    after all the site has helped me, im going to fork over my 25 dollars pretty soon.
    anyway, an update. took the driveshaft completely off got both ujoints removed and replaced with new but then had to go to work. i am off work now, but it is midnite so i will have to replace tomorrow afternoon. once i hook it back up, how much trans fluid should be poured into the tcase? ive only got a quart handy but ive never rebuilt or even opend a tcase before. i know for sure it takes trans fluid because the fluid that came out is pink.
