Tcase
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by James90, May 22, 2000.
  1. James90
    James90 1/2 ton status
    May 18, 2000
    986
    Rocky Mount NC
    is the NP241 a good T case or just a pace of stock junk?
    and if so what sould I get? the NP205 is good right?
    Go prepared
    90 k5 soon to be big, bad, and mean
  2. Truckfan2
    Truckfan2 1/2 ton status
    Apr 10, 2000
    343
    Northern IL
    The NP205 is good if you have the money to adapt it to the 700r4.
    NEVER been stuck... *yet* (4wheeling)
    Stuck for 10 months (At school)
  3. Jason73K5
    Jason73K5 1/2 ton status
    592
    Fresno, Ca
    The NP-241 is a fairly strong t-case. Nothing is as strong as the 205, but if you're not having any problems, there is no reason to spend the extra cash for the swap. The 241 also has a couple of good aftermarket upgrades available such as the slip yoke eliminator kit and 4:1 low gear sets. The 241 is also much lighter than a 205 and is fairly easy and cheap to rebuild.
  4. Truckfan2
    Apr 10, 2000
    343
    Northern IL
    Jason, where do you get the 4:1 kits?
  5. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    The 241 is a good, strong, light case. Unless you plan to run 500+ HP, there is no reason to change. It also has the advantage of a 2.7:1 (?) low range, vs. the 205's 2:1.
    Tim
    1970 Blazer CST 4X4 350 SM465 NP205
    1987 Suburban 4X4 350
    1988 Chevy Pickup 4X4 350
