TCC Solenoid on a 700 uses 12V Direct.?..
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Jaguargt, Aug 29, 2003.
  1. Jaguargt
    Jaguargt Registered Member
    Mar 14, 2003
    46
    Guatemala
    or i need to use a Resistor or a transistor, a friend says that it uses only 0.5 amp., but i think that the amp it's given by the consumption of the solenoid? right? thanx.
  2. dyeager535
    26,979
    Almost everything in the truck gets a full 12V, and the TCC is one of them.
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    pretty much everything cept heater blower fan low/medium speeds, tryingto thinkofanything else, but cant rightnow,wipers are variable ground controlled, and so is fuel guage sending unit system also,.
    good luck
  4. Jaguargt
    Mar 14, 2003
    46
    Guatemala
    o.k. thanks, do you recommend to use the Wiring kit from Painless?
