TCI lift part questions
Discussion in 'OffRoad Design' started by nvrenuf, Oct 8, 2002.
  1. nvrenuf
    Jan 7, 2002
    Mobile, Al.
    I'm interested in the 4" HD front springs, I saw them listed for $200 - does that include bushings? Does the u-bolt set price apply to a front Dana 60 and/or rear 14 bolt with the square down style u-bolts? Also how much is a Dana 60 steering block?
    Thanks for your time.
  2. If you read the listing its just the springs. the kit is 215 for 4" front spring but they are not HD. The front spring kit comes with bushings and u-bolts. If you still have doubts you can always call ORD.
  3. Stephen
    Sep 15, 2000
    Carbondale Colorado
    The spring kit prices are for D44/10B only, not with D60 ubolts. Since we have to have those bolts custom made, they cost more.
    For the rear, we don't even carry a square ubolt for a 1-ton rear, we encourage you to switch over to the 3/4T style bolts with the threads on the top and no plate under the axle.
    D60 steering block kit should be about $95.00.
