TCI Tranny Pan...Good???
Discussion in 'The Garage' started by kgillyk5, Apr 29, 2004.
  1. kgillyk5
    kgillyk5 1/2 ton status
    May 29, 2003
    1,830
    Fultonville, NY USA
    summit link:TCI-378000
    Anyone running this TCI alum. deep pan. Its a little cheaper then the B&M model. I need to order some parts today. I'll be doin' the temp gauge and the sensor in the pan plug trick as soon as I can line all the parts up.
    Anyone whose done this?..anything you would do different or parts you would endorse or not recommend?
    Thanks...
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Hopefully someone can speak up with first-hand experience with that pan, but be careful, I know that with some deep aluminum pans, you can have clearance problems between it and the front driveshaft.
  3. ratzila
    ratzila 1/2 ton status
    Aug 9, 2003
    691
    Mobile,Al
    I had a b&m deep aluminum pan for a th400.When I went with the high angle driveshaft I had to swap a stock one back in. We still had to notch the stock one for clearance.
  4. wasted wages
    wasted wages 3/4 ton status
    Dec 3, 2003
    9,194
    Dallas Texas
    I have a (T-400) TCI aluminum deep pan on my K5 W/ 205 and 1410 u-joints and 3" drive shaft (front and rear) with 8" lift and have no clearance problems.
    I like the cast pans as they add strength to the case.
    The pan seals perfectly and has never leaked,, and the drain plug is a plus,,,, /forums/images/graemlins/peace.gif /forums/images/graemlins/peace.gif /forums/images/graemlins/peace.gif /forums/images/graemlins/peace.gif
  5. kgillyk5
    May 29, 2003
    1,830
    Fultonville, NY USA
    Thanks guys...I think I'll go with it for now and deal with any lift /forums/images/graemlins/grind.gif when the x comes.
    Now if I can just find the wifes credit card... /forums/images/graemlins/ignore.gif
    /forums/images/graemlins/whistling.gif
  6. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    In my honest, anything by TCI is good. I couldn't tell you about any possible clearence issues, But TCI makes high quality products.
