TDC problem.
Discussion in 'The Garage' started by Anthonviking, Jan 16, 2006.
  1. Anthonviking
    Anthonviking Registered Member
    May 25, 2003
    44
    Varnamo, SWEDEN
    Iam helping a friend swaping his B18 (1.8 liter) volvo engine out of his Antitank wehicle. He found a donor out of his chevy van. Its a 305 year 84. We have kind of lost timing. So how many degrees TDC is a 305 1984?
    anthon/FS
  2. BIG*RED
    BIG*RED 1/2 ton status
    Mar 14, 2003
    1,094
    If i am understanding your question right TDC should be 0 degrees with the number 1 pistion in full up stoke..
    as for ignition timming i would start at 6 degreeb before tdc..
    i hope i answered your question
  3. muscle
    muscle 1/2 ton status
    May 28, 2000
    408
    Show Low, AZ
    if your speaking of ignition timing i would start at 12 btdc
  4. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    my dads 85 305 ignition timing is 4* BTDC
  5. BIG*RED
    Mar 14, 2003
    1,094
    12 degress BTDC on a 305?...wow never heard that.. my 350HO with high compression and 93 octane gas is only at 10 btdc....
  6. muscle
    May 28, 2000
    408
    Show Low, AZ
    wow big differance in base timing here so far. my 305 would run like crap at anything less. wonder if altitude was part of that.
  7. muscle
    May 28, 2000
    408
    Show Low, AZ
    my 400 sbc will backfire at anything less that 14
  8. BIG*RED
    Mar 14, 2003
    1,094
    Yes but look at the picture, were talking about what apeard to be a stock 305 low compression, maybe 120hp if he is lucky..
    and there is a slight difference between a 400 and a 305..
    6 or 4 btdc is a good place to start
  9. theperfectgarage
    theperfectgarage 1/2 ton status
    Oct 5, 2005
    988
    tucson arizona
    Yeah, but dont forget your elevation, I run 12-14 in the White mtn,s and 8 here in Tucson. BTW I pm'ed ya.I'll get you info tonight on discs.
  10. Anthonviking
    May 25, 2003
    44
    Varnamo, SWEDEN
    Yeaa. Lots of numers to test..... So far, actually earlier to day we tried 8 deg BTDC and it did NOT work (thats what my chevy 76 run).
    anthon/FS
  11. theperfectgarage
    Oct 5, 2005
    988
    tucson arizona
    # 1 piston at tdc and both valves CLOSED, thats tdc, otherwise your 180 out.
  12. Anthonviking
    May 25, 2003
    44
    Varnamo, SWEDEN
    Sheoldeblaze! You are a real "sharpeye". Yepp its a stock 305 120 hp. But alot mor fun than its original B18 aprox 40 HP!!!! Iam great thankful for all of your kvick answers. THANKS!!!!!!!!!!!
    anthon/FS
  13. muscle
    May 28, 2000
    408
    Show Low, AZ
    definately what i think it is...
    ill go with that
  14. Anthonviking
    May 25, 2003
    44
    Varnamo, SWEDEN
    That is checked out. It have been running, but just for some minutes and then it loses power and stops and wont start up!
    anthon/FS
  15. muscle
    May 28, 2000
    408
    Show Low, AZ
    fuel blockage? if not then check ignition module, coil
  16. Anthonviking
    May 25, 2003
    44
    Varnamo, SWEDEN
    Fuel there is and coil is ok.....
    anthon/FS
