Teach me how to drive my SM465!
Discussion in 'The Garage' started by Ben B., Feb 4, 2007.
  1. Ben B.
    Ben B. 1/2 ton status
    Sep 1, 2005
    352
    Central PA
    I've had my truck for a while, and I can drive it fine, but how do I downshift properly?
    Whenever I'm going up a hill and need more grunt I just push the clutch in and downshift, and this usually locks the rearend up and slows me way down.
    do I have to put it in neutral, rev it, then downshift?
    Help :(
  2. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    The 465 is a wide ratio transmission you cant drive it like a car. When you downshift you need to rev the engine slightly while letting out the clutch. You basically need to get the engine close to where you think it would be for the speed you are going and it will not lock up the rear.
    Ira
  3. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    its called double clutching and it helps when you downshift. it will make it easier to get it in gear and keep from slowing you down as much. I hope your talking about going from 4th to 3rd. your rear end shouldnt lock up when you downshift unless your dropping to a gear thats too low.
  4. Ben B.
    Sep 1, 2005
    352
    Central PA
    Yup. 4th to 3rd, it slows me down way too much when I need momentum, and it locks up.
  5. Ben B.
    Sep 1, 2005
    352
    Central PA
    If i'm buzzin down the highway at like 60, turning around 2k rpm...can I downshift to overtake or whatever?
  6. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,924
    336
    Fort McMurray, Alberta
    You can, but your engine will be up around 5000 rpm... I just never bothered trying to pass people on the highway, unless I had a lot of time to do so, or if they were going exceptionally slow...
    Typically, I wouldn't shift back to 3rd unless I was going 45 mph, or slower
  7. Ben B.
    Sep 1, 2005
    352
    Central PA
    Guess I'll just be cruisin on the freeway, but if I need to downshift on a hill or whatever, I go to downshift like i normally would, but rev just before i let the clutch out into the lower gear?
  8. BlaKK54Speed
    BlaKK54Speed 1/2 ton status
    Dec 14, 2006
    242
    Omaha, NE
    i drive mine just like i drive my car, except slower and easier, and it never locks up when im down shifting. sounds like operator error
  9. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    3rd is 1.7:1 ratio, so is you're running down the freeway at 2400 rpm and try to downshift you'll be doing 4000 rpm at the same speed and not have much left before needing to hit 4th again. I have never downshifted to 3rd unless i'm doing under 45 mph. You should pretty much be lugging in 4th before attempting to downshift, and even then the wide spacing between gears means it'll be roaring in 3rd.
    What gears are you running?
    Rene
  10. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Just brng the revs up before you let the clutch out for 3rd. Easy. I need to do it all the time with my highway-geared 6.2L.
  11. Ben B.
    Sep 1, 2005
    352
    Central PA
    Rene, it turns pretty low rpms on the highway but I'm also only currently running 31's. I'd say 3.08s.
    How fast should i let the clutch out when downshifting?
  12. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    It's not such a matter of how fast, rather how smooth and with how much throttle.
    I could run through my gears in my last one without the clutch by matching engine rpm to where it needed...up and down shifts.
    It probably wasn't the best thing to do to it, but you get the idea.
    You need to learn to listen and know when it will go into gear at what speed.
    Once you get that down, you'll know when you need and can shift smoothly and yes, quickly.
