tearing my hair out in frustration
Discussion in 'The Garage' started by bronderslev, Jun 11, 2006.
  1. bronderslev
    bronderslev Registered Member
    Mar 17, 2006
    21
    denmark
    the dumb dane are back....
    i got this 6.2 L diesel, and i changed starter on it, no problem and it started right away, then i turn´d it of and now i cant get it to start again... i have already purged the fuel system that wasent it... fore f*** sake i need some help...
  2. twosnvrlose
    twosnvrlose Registered Member
    Jun 4, 2006
    27
    Canada
    I'm asumeing that its turning over right? check your glow pluggs and see if your getting power if you do and you have air ,fuel and a ignition source it should start
  3. bronderslev
    Mar 17, 2006
    21
    denmark
    it turnes, new glow plugs, new airfilter, and its getting fuel... but still wont start
  4. tRustyK5
    Jul 23, 2000
    36,169
    1,369
    E-town baby!
    Check for power at the big pink wire on top of the injection pump when the key is in the run position. If that is OK the shut off solenoid may be sticky. That solenoid is only usually a problem when the motor is hot though.
    Rene
  5. bronderslev
    Mar 17, 2006
    21
    denmark
    thank you ill try that and if it dont work ill be back
