Tech Article re: door hinge pins
Discussion in 'The Garage' started by bnate, Mar 1, 2006.
  1. bnate
    bnate 1/2 ton status
    Mar 6, 2004
    138
    San Jose, CA
    So like the NV4500 question.....has anyone actually accomplished this??
    I tried to drill the pins (as suggested "Help" section of auto parts store for door hinge pins). It is hardened steel. I have a table vise and tried my buddy's drill press too. I tried a few different drill bits w/out success.
    Article reference:
    http://coloradok5.com/doorhingepins.shtml
    "I did this by holding the pin with the Vise Grips in one hand and the drill in the other. It would have been much easier with either a Drill Press or a Table Vise, but this method worked fine for me. I used a 5/64" drill bit, and it seemed to be the perfect size."
    Suggestions?
    Thanks in advance.
  2. Elevator Man
    Elevator Man 1/2 ton status
    Dec 23, 2005
    240
    Bigelow, Arkansas
    I did the same thing. you will have to get some carbide drill bits. they are very expensive. you might take them too a machine shop and get them to do it but they will charge an arm and leg. another option woud be to take a dremel tool and groove the end off the pin. then you could put a E-clip or snap ring on there. I wish they would have mentioned all this extra work too!!!!!!
  3. redneckdude
    redneckdude 1/2 ton status
    Feb 21, 2004
    578
    Augusta, GA
    run them w/o the hitch pins. I run mine like this and have only had to slide one pin back in once in the past year. the doors are heavy enough to where you don't have to worry about the pins just slipping out.
  4. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    I've done this on my driver's door and it worked great. I can have my door off in just a few minutes. That's with unhooking the wires. I eliminated quite a few of my wires when I switched over to manual windows. :D
    I plan on doing my passenger door this month sometime.
    I have a bench vise in my garage. That made it very easy to drill the pins. I also used a punch on the pin before I drilled it. I started with a very small bit to drill the pilot hole. Then I went up to the right size bit. :thumb:
    Rick
  5. Elevator Man
    Dec 23, 2005
    240
    Bigelow, Arkansas
    What kind of drill bit did you us rick88? I center punched my pins and every drill bit I had in my shop wouldn't even scratch the pins.
  6. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    I'm definitely planning on this mod, perhaps this summer. The drilling business concerns me. Would my drill press make it easier? If I can ever find that darn chuck key...lol... I would definitely like to have all the information before I go diving into that project.
    thanks,
    James
  7. rick88blaze
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    To be honest I'm not sure. Just about every set of drill bits I buy are high speed bits made for metal. I have them all in a coffee can anymore, but most of them are black and decker bought at Wal-Mart, Lowe's and Home Depot or other places like that.
    I don't know if it matters where you buy the pins, but I got mine out of the help section at Advance Auto here in Bellevue. By the time I got done drilling out both pins the bits were pretty dull. They probably weren't the sharpest when I started either. :D
    Rick
    Oh yeah, I just remebered that I kind of rested the bit on the vise jaws to help guide it. That helped out a lot!
  8. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Get someone to center drill the hole for you with a center drill to get thru the case hardened pin, then you can use a HSS drill bit.
  9. bnate
    Mar 6, 2004
    138
    San Jose, CA
    Thanks for all of the responses.
    I tried the carbide drill bits on the first pin. Yes, they are expensive.
    A buddy of mine is a machinist and he couldn't bear to watch me suffer anymore. He welded an extension onto the pin and drilled the "softer" steel with the drill press. Should hold up good, since the hardened steel is the part that is in the hinge...extension only for the cotter pin.
    Thanks again all.
  10. B_to_C
    B_to_C 1/2 ton status Author
    Jan 15, 2003
    1,861
    In Government Housing
    Huh :dunno:
    Glad you got it worked out. Maybe I had super special drill bits or seomthing :thinking:
    I also notice that through the quote I didn't mention that I started with a VERY small bit and worked my way up to the 5/64 :doah:
