Tech Help with Warn Winch
Discussion in 'The Garage' started by k5blazerus, Feb 23, 2003.
  1. k5blazerus
    k5blazerus 1/2 ton status
    Apr 22, 2001
    654
    Bend, OR
    I need some help with my Warn Winch.
    Last night I pulled my friends toyota out with the winch. I did a short pull with the winch for about 15 seconds.
    The toyota got stuck again I hooked up the winch it the switch and all it did was make a buzzing sound sort of like when a starter is dead. I am thinking maybe it is the solinoid but compleatly shure. Any help would be cool.
    Colin
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Clean your battery cable connections. Mine does this every few months or so. I clean up the connections and away it goes. /forums/images/graemlins/grin.gif
  3. k5blazerus
    Apr 22, 2001
    654
    Bend, OR
    I will go try that real quick.
  4. k5blazerus
    Apr 22, 2001
    654
    Bend, OR
    Sandman you are the man.
    Just dirty connection I overlooked
  5. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Just a bit of info on those solenoid packs, if a solenoid ever goes out, all they are are standard ford starter solenoids /forums/images/graemlins/shocked.gif just go to auto parts store and pick on up /forums/images/graemlins/thumb.gif
  6. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    It's just a Ford solenoid? Man, that's good info.
    Dumb question - do the i series winches and the non-i series winches use the same solenoid, or what?
    -- Mike
  7. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    I am not 100% sure but, I believe they are continuous duty solenoids which look just like a ford starter solenoid but not the same thing. In a pinch I am sure a ford starter solenoid would get the job done but it won't last long. Just my $.02
  8. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    cool! /forums/images/graemlins/cool.gif
