tech needed... Suburban Tranny/TCase
Discussion in 'The Garage' started by PhoenixZorn, May 1, 2006.
  1. PhoenixZorn
    PhoenixZorn 1/2 ton status
    Mar 17, 2005
    1,734
    West Allis, WI
    Ok... so I'm getting this 1982 Burb with a 6.2L, 700R4/NP208 combo. The T-Case is bad, so I've been looking for a replacement. My boss and friends think I can't put my 465/208 combo in the burb, that I'm not mechanically enclined enough to do it... I beg to differ, but they don't listen real well. I don't have the extras that I need to do the 465 swap, like pedals and linkage, because I'm using the parts from my burned truck. I've read through the auto-manual swap tech, and I understand the process well enough.
    What do you guys think? Spend $100+ on a t-case or spend $100+ on pedals and linkage to make it work with the 465? Please post more than an answer to my question... please tell me why you feel I should do either option.
    By the way, the loss of overdrive will be compensated for by replacing the stock 29" tires with 32" BFG A/Ts, which should put me in almost the same gearing range in 4th gear. It has 3.73 gears and it's a half ton... the only modifications that will be required is driveshaft length changes and transmission tunnel replacement or cutting.
  2. R77K10
    R77K10 Banned
    Mar 15, 2006
    564
    Lincoln IL
    3.73 is plenty fine for the highway no problem at all
    been there done it
    many times
    and 4.10 also
    lots
    4.55-4.57 isnt so good though
    good luck
  3. PhoenixZorn
    Mar 17, 2005
    1,734
    West Allis, WI
    Thanks for that info, but I really need opinions on whether or not to attempt the manual swap on a Burb.... it seems to be few and far between that the swap actually happens with such a large vehicle, and the fact that no burbs ever came with a stick makes me hesitate.
    I guess I just need the go-ahead from my boyz (and girlz) here on the site... (sorry about the ghetto speak y'all... )
  4. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    why not swap the input from the busted case into the 465 case and install that into the burb? if the input is busted, ive got a 27 spline input from a 208 ill ship you.
  5. k30bb468
    k30bb468 1/2 ton status Premium Member
    Oct 2, 2004
    955
    NW Pennsylvania
    Not true, I'm going to get the hydro set-up
    from a Burb next week. :D
    As far as the swap it wouldn't be any different than doing it in a blazer or in a
    truck,so if ya want a manual go for it,if ya
    want to stay with an auto just swap the input
    like ryan22re said to the unbroken 208 that you already have and your back in business
  6. hack500
    hack500 1/2 ton status
    Sep 16, 2005
    523
    Templeton, Ma
    I had a 'burban with a stick - and yes, it was a factory installed setup.
