Technical Questions About GM 14FF Dually Axle
Discussion in 'The Garage' started by K5BLT4FUN, Apr 14, 2002.
  1. K5BLT4FUN
    K5BLT4FUN 1/2 ton status Premium Member
    Feb 28, 2000
    496
    Peculiar, MO USA
    I have a few questions about the GM 14FF Dually axle. What is the WMS to WMS dimension? Is there more than one width of Dually axle? What application has the Dually axle?
    Any info that I can get will be helpful in my project.
    Thanks Layne
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    There are two axles available for the GM line.
    The narrower of the two is the 14FF, which is about 63" WMS to WMS. This axle was available in the trucks that were cab-and-chassis models, etc.
    The other axle is the D70, with a wider track, even wider than the front axles. Not positive on the WMS, but it's something like 75" or so.
    These rears are standard axles on the duallies that have the regular bed with the wide fiberglass fenders.
    So, it boils down to if you find a 1 ton with the bed and fenders on it, it will have the D70.
    If you find a flatbed truck or even a utility bed truck, it will have the 14FF.
    BUT, I have seen people to take off the beds and install the flat beds or utility beds before.
    The only surefire way to check is to crawl down and inspect the cover. /forums/images/icons/wink.gif
  3. so will single wheel 14 bolt hubs and drums fit on a dually dana 70? the cab chassie would have to have spacers to use in a single wheel ap. right?
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    No. 14FF parts and D70 parts are two different things. Both are manufactured by two different companies and totally not compatible.
