teflon gear oil
Discussion in 'The Garage' started by bluboti, Nov 7, 2002.
  1. bluboti
    bluboti Registered Member
    May 6, 2002
    37
    west virginia --yes-us
    I saw that walmart is selling slick50 gear oil,i need to drain and refill mine soon(its an open diff) any ideas on how this might perform?
  2. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    Here is my .02 worth skip the Slick 50 and use a Synthetic Gear oil.
    any GOOD Synthetic oil will do more for you and your diffs than Slick 50 ever could.
    Eric
  3. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Or if the synthetic stuff is too expensive for you, just change it out yearly with regular gear oil. Stay away from teflon-based products.......
  4. bluboti
    May 6, 2002
    37
    The slick50 is 5.00 a guart,so i dont care about price.I know the teflon is not good in an engine.But with mostly just gears slinging the oil with teflon around it would seem to aid friction,heat aid mpg.
