Teflon leaf spring liners
Discussion in 'The Garage' started by Musclerodz, Aug 24, 2005.
  1. Musclerodz
    Musclerodz 1/2 ton status
    Apr 23, 2005
    121
    Washington, OK
    Where can i get teflon liners for my leaf springs. Just had them fresh powdercoated and want to eliminate some binding and possible squeaking. I checked with GM and everything up to 87 has been discontinued on their computers.
    mike
  2. Kiwi John
    Kiwi John 1/2 ton status
    Jun 24, 2005
    249
    West Sussex, England, U.K.
    There is a thread posted on page 2 by scrappy88 titled 'UHMW-PE strips...' that has 7 replies with info to help you. Sorry I cant do the linking. just read it last nite.
  3. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    14,686
    492
    Afton / Star Valley Wyoming
    Contact a local spring supplier or someone like Deaver or Eaton or National they should have what you are looking for
  4. scrappy88
    scrappy88 1/2 ton status
    Mar 14, 2003
    314
    Loveland, CO
    If you've got them apart and freshly powdercoated I'd skip those little spring pads and line the whole things with .030 to .060" UHMW-PE. Eliminates all metal to metal contact. It'll cost a bit more but I think it's worth it. I got mine at www.mcmaster.com and used the .050" adhesive backed in 6" wide.. just cut it to fit the springs. Part number is 7701T49.
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,385
    Georgetown, TX
    If you look closely at the later model spring packs that have the sliders on the ends of each leaf, you'll see that the springs don't even touch each other. :eek1: There is a spacer between each leaf at the center pin, and the slide pads at the ends, so there's always a gap between the leaves. Ya can't get much lower friction that that! :rolleyes:
  6. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,120
    X2. I have been wondering if I could get some of the pads for the centering pin from the newer trucks and use them on my older springs?
    And to the original poster - as someone else mentioned, try a local spring shop. I bought some locally for 75 cents a piece.
    :wink1:
  7. Musclerodz
    Apr 23, 2005
    121
    Washington, OK
    I read the thread mentioned a couple a days ago but it has had a few more posts since. TO use those snaps I would have to drill hole in my springs and I don't want to do that. I have Grainger local to me, I will try them for the tape stuff. Thanks
    Mike
  8. HarryH3
    May 31, 2000
    10,385
    Georgetown, TX
    Those "pads" at the center pin are just pieces of galvanized sheet metal. Maybe 1/16th of an inch thick.
    I looked into adding the plastic sliders at the ends of the springs to an older set of springs. The spring shop said $5 PER HOLE DRILLED, :eek1: so I just grabbed a set of newer springs and freshened 'em up instead. :cool1:
