Teflon pads?
Discussion in 'The Garage' started by sled_dog, Oct 23, 2003.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Ok so I put an axle under the k5 and moved it into the garage(it snowed today so no more outside). So next thing to do is pull apart the rear suspension. I'm going to remove one leaf(I believe previous owner added an add-a-leaf), and cut down my overloads so they don't do any otherload stuff just act as zero rates. I would like to put new teflon pads on the springs as well. Where could I get some?
  2. If memory serves me correctly, you can get those from the dealer for a dime each. But then again, the prices are always higher at the dealer so you might want to shop around. /forums/images/graemlins/thumb.gif
  3. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    [darn] teflon, it sucks. what you need is some 0.030-0.060" UHMW-PE. It comes in a roll... 3" wide and you can cut it with scissors. Get some at ur local plastic supply place. Cut it in strips as long/wide as each leaf in ur pack and drill a hole in the center for the center pin. UHMW-PE resists cold flow to a greater degree than teflon. With this stuff in there, you're springs WON'T bind due to friciton between the leaves. May cost a little more than cheapo teflon pads, but it is a superior material for this application. Here is a pic of it in my spring pack...
    pic
    Ive had this in my pack for prolly 3 years now, and its good as new... this stuff is tuff!! /forums/images/graemlins/thumb.gif
    j
  4. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    How did you make that rear shock mount boss?
  5. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    55willy includes those lower shock mounts with his shock relocation/x-member kit.
    j
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I just rebuilt a set of spring packs from an '88 Blazer. It already had the factory plastic sliders at the ends of the leaves, but they were pretty worn after 109K miles. I bought new ones from a local spring shop for 65 cents each.
    Teflon won't work in this application. It cold-flows under pressure and would just squish out from between the springs in a short time. /forums/images/graemlins/eek.gif
  7. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    I'm pretty sure the factory slider pads are UHMW and not teflon...although everyone calls the stuff teflon. I got mine at a local spring shop for 46 cents a piece. I sprayed the leafs with epoxy enamel after cleaning them up and added the new tips. I couldn't see a reason to re-invent the wheel, and I suck with scissors.../forums/images/graemlins/rotfl.gif
    Rene
  8. chubbybob
    chubbybob 1/2 ton status
    Oct 18, 2002
    730
    UHMW is the stuff. its the same thing that they use on aluminum jet boats in canada to slide over rocks in shallow streams. they cover the whole bottom of their boats and the stuff gets the crap beat out of it and holds up better than anything else. I run it in my springs the stuff that comes in factory springs are just regular plastic. UHMW wasnt on the market till about 5 years ago.
  9. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    UHMW has been around longer than 5 years...
    Rene
  10. chubbybob
    Oct 18, 2002
    730
    UHMW has been around for probably 30 years but not to the public. 5 years ago if you walked into a harware store and said you needed some UHMW they wouldnt have known what you were talking about.
  11. jms
    jms 1/2 ton status Author
    Jan 24, 2001
    1,683
    I've done the UHMW-PE tape and have a hard time keeping it in the spring pack; in fact, most of the tape on the lower leafs worked its way out sideways from the pack at BB'03. The smooth surface isn't the problem for me - it's the glue side that doesn't want to stick. Leafs are painted with POR15 and MetalMask. The springs are indeed very responsive with this setup. If anybody has a tip how to make the tape adhere better to the leafs, I'm all ears...
  12. TWISTEDJACK
    TWISTEDJACK 1/2 ton status GMOTM Winner
    Jul 24, 2002
    882
    Boise, ID
    I have the same problems. I have a lot of flex but the pad under the main leaf I am always messing with. I finally just but a little black tape around in and the spring to hold it in place. /forums/images/graemlins/frown.gif
  13. shewheeler
    shewheeler 1/2 ton status
    May 4, 2001
    3,384
    Hollister, CA
    I think BRB is the resident expert on padding and which type of pad would work best for this application /forums/images/graemlins/ears.gif
