Teflon tape to stop oil leak from plug?
Discussion in 'The Garage' started by RENO88, Jan 2, 2008.
  1. RENO88
    RENO88 1/2 ton status
    Aug 1, 2007
    260
    San Diego
    So I've alsways had a small leak coming from my oil pan drain plug. Today, I changed my oil, new plug and its still leaking from there. Im thinking the jack-ass previous owner over torqued it a few times. Should I try teflon to prevent oil pan replacement? I dont want anymore oil stains in my driveway!!
  2. Streetgliderx
    Streetgliderx 1/2 ton status
    Jun 16, 2007
    287
    Tuscumbia AL
    i teflon mine on a 98 ton454 i got those qualified goodWRENCH techs at the jiffy lube partially stripped mine one time i use tape and a dap of pipe thread sealer we use on gas lines. works good i have teflon and sealer on threads tested to 2800psi it holds.
  3. RENO88
    Aug 1, 2007
    260
    San Diego
    Nice! Good to hear that it worked for you. I'll be doing this myself this weekend at the latest.
  4. tRustyK5
    Jul 23, 2000
    35,406
    406
    E-town baby!
    If I recall right, there should be a captive copper washer on your drain plug. I'd make sure that was still there first. If the washer is still there, and the threads on the pan are OK, it shouldn't leak and shouldn't take a ton of torque to get it tight enough to not leak.
    The seal area isn't the threads themselves, but rather the seating face where the drain plugs tightens up to.
    Rene
  5. RENO88
    Aug 1, 2007
    260
    San Diego
    There's still a washer there, Its new with the plug. I figure I'll try to save a little change in hopes of not replacing the pan. You know what I mean? I know what I mean:rolleyes: Gotta try it.
  6. tRustyK5
    Jul 23, 2000
    35,406
    406
    E-town baby!
    So the threads in the pan are a bit 'dodgy'... is that what you're saying? :doah:
    Rene
  7. redneckdude
    redneckdude 1/2 ton status
    Feb 21, 2004
    578
    Augusta, GA
    IF it is slightly stripped...and that doesn't solve it, you might want to give an oversized plug a shot. they make single and double oversized plugs. it acts as a tap the first time it goes in so it does remove some metal but usually works.
  8. RENO88
    Aug 1, 2007
    260
    San Diego
    Ok Redneck, I'll try the teflon first, then oversize plug. I think I'll order a new pan, and gasket anyway.
  9. 89yimmiJ
    89yimmiJ 1/2 ton status
    Feb 3, 2005
    259
    Phoenix, AZ
    Remember that Teflon is a lubricant, not a sealant. The purpose of putting teflon on Pipe Threads(NPT) is so that you can tighten them more allowing the threads to seal. Since a Drain Plug is not pipe thread, and you are using the teflon as a sealant, it will only be a short term fix. (ie. to get you home, off a trail, etc.)
    A simple, long term fix is to drill it oversize and weld a nut on the outside of the pan and use a new drainplug.
    Personally, i'd spend a couple hours, pull the pan and fix it right, and not have to worry about whether or not it will leak and ruin my motor.
  10. RENO88
    Aug 1, 2007
    260
    San Diego
    Yeah, 50 or so dollars will save me a few thousand.
  11. RENO88
    Aug 1, 2007
    260
    San Diego
    And let me tell you, the leak is BAD! I put a small rag under there while here at work, and its almost saturated. I'll prolly need to add half quart before I drive home today.
  12. Streetgliderx
    Jun 16, 2007
    287
    Tuscumbia AL
    i been running mine like this since early 99 i bought the truck new in 98. 210,000 miles and i still not leakin
  13. RENO88
    Aug 1, 2007
    260
    San Diego
    So I used Quicksteel on my little issue. No leaks! We'll see what happens when I drive her to work. This basically means that I have approx 3 months to get a new pan in there..
