teflon tape
Discussion in 'The Garage' started by jroymcd, Jul 22, 2005.
  1. jroymcd
    jroymcd Registered Member
    Jul 19, 2005
    23
    nor cal
    can you use teflon tape on gas fittings
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    don't, they should be compression fittings, if they are leaking or something, there is a problem with the fitting and it should be replaced.
  3. jroymcd
    Jul 19, 2005
    23
    nor cal
    its for a universal fuel filter. it comes with a few different size fittings for different size hoses. says to use teflon but i did not like the sounds of that
  4. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    yup for that application put a few raps on it gas wont mess up teflon tape
  5. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    if it says to use it, do it. Odd though.
  6. ryoken
    Jun 13, 2003
    29,622
    1,376
    Jersey Shore
    not really... tons of gas applications use NPT...
    that being said, i rarely use teflon... i prefer thread sealent usually... ;)
  7. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Only use teflon tape on pipe threads. Not on Inverted Flare, AN, or other fittings, those are designed to seal on the flare and not in the threads.
    Leave the first full thread bare of tape. Makes it much harder for a sliver of tape to get into the the system.
    Lately at work I've been using Lock-tite 545 which is a pipe thread sealant. Works great and you don't have to tighten the snot out of the fitting to make it seal. Which a good thing since of those sensors cost more than I make in a month.
  8. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    this is true but universal fuel filters use NPT
  9. jroymcd
    Jul 19, 2005
    23
    nor cal
    are the glass universal fuel filters any good
  10. puckhead
    puckhead 1/2 ton status
    Jun 17, 2005
    112
    colorado
    glass filter can break on the trail if something happens and poof instant
    car BQ
  11. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    I went to a local speed shop and got a wix which is a really good filter and its clear plastic(ends are white) and but there all 3/8's
  12. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    I dont personally like the clear ones. Their filter media is so small.. you'd be changing it often. If you really want a really good non tool removable & replaceable one, try a Racor.
  13. mrk5
    Apr 20, 2004
    12,332
    1,040
    Northern Colorado
    I don't know if all teflon tape is okay for gas applications, but I did notice the other day some teflon tape at ACE said it was specifically okay for gas.
  14. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    AHHH ! The voice of reason. :D
  15. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I sell it at work myself . Teflon tape for gas lines , is yellow . Its mainly for natural gas , but I assume it would work better in this application as well .
  16. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The first time you have to rip apart a carb or swap out an injector because a small sliver to Teflon tape is clogging it, you'll know why it's a bad idea to use it for fuel lines. Get a filter that doesn't use pipe thread. :rolleyes: Save your Teflon tape for house plumbing. :cool1:
