teflon
Discussion in 'The Garage' started by tecton, Mar 28, 2004.
  1. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    would it be pratical to coat things on your truck with teflon to keep mud/dirt from adhereing?
    chrome is so hard to keep clean
  2. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Sure, they just came out with teflon wheels
  3. tecton
    Dec 1, 2002
    1,553
    WV
    what about spray on? how does it do on paint or glass
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Teflon has to be applied to metal in a very controlled process. You can't just spray it from a can and expect it to stick. /forums/images/graemlins/frown.gif It has to be heated to very high temps in order to bind with the underlying metal. The temp required is around 800 degrees F (thus the reason that pouring Teflon bits into an engine is a total waste of money).
    Here's a link I found that talks a little bit about the process: Teflon coatings
