tell me about 3/4 eliptical
Discussion in 'Center Of Gravity' started by big83chevy4x4, Aug 13, 2004.
  1. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i know the basic design, is there anything else? advantages, disadvantages? how does it handle at somewhat high speeds? down steep hills? what springs to use? /forums/images/graemlins/1zhelp.gif
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    They guy that runs it on here TJ (Denver75K5) has spoken bad words about it. He is going to do a link suspension with coils is the rumor.
    A buddy of mine had a buggy leaf on his front srpings on his K5 for years. I talked to him about it and he HIGHLY recommended that I NOT do it. With it on the front springs he said that the front axle would try and walk away from the truck when he crested uphill ledges.
    In the rear I don't remember exactly why TJ didn't like it.
    Harley
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    TJs problem was loadin of the springs I think. He'd jump on the gas and the rear end of the truck would lift up quite a bit.
  4. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    woah that sounds scary. can someone explain how the 3/4 eliptical works? ive seen pics, but dont quite understand...
  5. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i PMed TJ, hopefully he will post here to tell about his experiances.
    if the rear end lifted up, wouldn't an anti wrap bar help? /forums/images/graemlins/thinking.gif
  6. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    instead of the shackle being solidly mounted on the frame, it is atached to a nother spring. now when the rear is droped, the second spring lets the shackel down to allow for more flex.
  7. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    okay, thats makes that picture 100% now. I understand, thanks!
  8. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Marv (guy with buggy springs on the front that harley mentioned) and I bounced around some ideas/alternatives about 3/4 set ups recently. First they are real loose in the seat. A track (panhard) bar is often necessary. The frame moves alot when the spring unloads, and the buggy leaf acts like a 2 foot long wobble shackle letting the axle have all kinds of leverage on the springs (bad thing). I also feel they allow the axle to walk too far under as it flexes wich in turn causes rear steer input. Then there is the point of axle wrap. The rear half of the leaf does little to fight axle wrap as it will just push/pull the buggy leaf as the torque demands. They can be made to work, I know there are people using them, and using them well. I looked into running one but ran some numbers (made some models) and it didn't do well enough for me.
    Just my .02
  9. zeroz400
    zeroz400 1/2 ton status
    May 30, 2004
    410
    Libertyville, IL
    How about 1/4 elliptical springs? They got crazy flex but i dont know if they're street legal. D and C Extreme Go there to suspension then 4link, thats the only place ive seen them.
    Later
  10. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    no reason it couldn't be street legal. but we have discussed this before, 1/4 elliptical under a full size truck is iffy. That D&C stuff is some serious springs but not sure about the arch on them.
  11. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Marv Springer runs a quarter elliptic 3 or 4 link suspension front and rear on his buggy. Flexes pretty good and still has room for improvement.
    Harley
  12. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
  13. justinf
    justinf 1/2 ton status
    Sep 23, 2003
    684
    Tuscola, Illinois
    I've got 3/4 elliptical in the rear of my jeep with a 3 link. Works well. You do feel some lift when you get on the gas and turning, but a lot of that is the springs. I have stock CJ springs (no lift) that are extremely whooped. All four main packs are in downward arch just sitting. I need to replace all four packs and it should tighten everything up.
    But overall I like the 3/4 elliptical, I haven't had any problems with it unloading and it flexes very well.
    I have been toying with the idea of going to coils though. /forums/images/graemlins/thinking.gif
  14. denver75k5
    denver75k5 1/2 ton status
    May 15, 2001
    1,017
    Somewhere In The Woods
    Other than a bit of unloading which a limit strap in the center of the axle mostley took care of it actually has served me well. BUT if I had it to do over I would have just linked it with coils or coilovers.
    Disadvantage:
    Unloading,
    Schackles hit everything,
    If the "Goofy leaf" breaks , your in trouble,
    Advantage:
    Quite a bit of droop for the rear.
    So, imo, if your looking for more flex youd be better off linking it or getting a set of alcan's.
  15. Big91RustyBucket
    Big91RustyBucket 1/2 ton status
    Mar 10, 2007
    1,429
    New Lenox IL, Area (Chi-town Suburb)
