tell me if this is a good idea
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by surpip, Oct 5, 2004.
  1. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    you know how on the later model trucks the fuel filler has a vent tube that runs parrell with the filler tube? im thinkin that i could use a "t" fitting to run the rear axle vent tube into. good idea or no?
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Isnt that vent tube so you can put gas into the tank without having it blow over the place? I think you would run the risk of cross contaminating both areas.
    Does that make sense? I'm not sure that I understood what you were proposing.
  3. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    I think you would for sure have gas in your axle. That tube allows air to escape from the fuel tank as you fill it. When its full some small amount of fuel will wash back down that vent line or up it since the tanks is full now.
  4. smprider112
    smprider112 1/2 ton status
    May 1, 2004
    624
    Beaverton,Oregon
    ya...BAD idea /forums/images/graemlins/shame.gif you'd end up with gas in yer diff....you could run the vent up to the fuel filler and just have it near it but not attached, if u want it up high like that /forums/images/graemlins/thumb.gif
  5. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    alright cool thanks for the advice!!! /forums/images/graemlins/waytogo.gif
