Tell me whats wrong with these??????
Discussion in 'The Garage' started by Scuba Steve, Feb 7, 2006.
  1. Scuba Steve
    Scuba Steve Registered Member
    Jul 17, 2002
    99
    Fort Bragg, NC
    These are pictures of the plugs that I pulled out today. I have listed the cylinder number on each of the plugs. Can anyone tell me whats going on in 6,7 and 8 please.
  2. bigtread
    bigtread Registered Member
    Nov 22, 2005
    32
    Virginia Beach Virginia
    Is that mud on no. 8
  3. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    what do they smell like. Thats usually a good indicator. Im not sure off the top of my head what the soot is. Either burning oil or running rich is my guess.
  4. sweetk30
    Nov 1, 2004
    25,552
    547
    horseheads , ny 14845
    125 look lean 678 look oil burnt fouled . major work needed .
    oh ya and thay are auto lights not acdelcos.
  5. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    number 8 looks like it suffered detonation. Notice the chunk of missing porcelain. Might account for the buildup, cause Im sure that led to a reduced spark.
    Also, since it just seems to be the back plugs, could be a leaking vacuum modulator on the transmission, since you have a th400. Sucking ATF up into the manifold and burning it. Pull the hose that goes down to the tranny off the manifold and see if it has any ATF in it.
  6. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    valve seals failing in certain cylinders, had another motor that did the same thing to me as well, even the current one in the Burb looks like that after awhile.
    that's not a chunk of ceramic missing, it's a chunk of the burnt oil that broke off.
    does the motor smoke alittle at start-ups?
  7. callmewaylon
    callmewaylon Registered Member
    Dec 15, 2004
    37
    Janesville WI
    You need to do a compression check. My guess is that cyl 8, maybe more will be low on compression. Does it burn oil? Last time I saw a plug like 8 the truck was using oil and low on compression and I had to keep changing the plug when it fouled out every 500 miles or so. My guess is you have at least 1 dead or dying cylinder.
    Mike
  8. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
  9. Scuba Steve
    Jul 17, 2002
    99
    Fort Bragg, NC
    Well this is what I feared. I think I will be getting a new engine here in the near future. Good thing taxes are coming in.
  10. merace19
    merace19 1/2 ton status
    Sep 19, 2003
    372
    Mobile, Alabama
  11. diesel4me
    Jul 24, 2003
    17,583
    945
    Massachussetts
    foul!
    They look oil fouled,even the ones that are heavily crusted with the tan ash deposits..oil additives leave that ash deposit,if enough oil gets to the plugs it turns them black and wet like coal..your #8 is ash deposits,probably due to bad valve stem seals..the ones like # 6 are oil fouled..
    I noticed the worst fouled plugs came from the rearmost cylinders..you might have clogged up oil return drain holes in the heads,it lets oil puddle up in the heads and flood the valve guides and seals,and allows too much to get in the cylinders..the puddles form in the rear near the firewall the most,since the motor tilts that way..
    You might try using hotter plugs..if they are R43TS,try R45TS instead..the brand of oil used can make a difference too..oil with a higher flash point will reduce the fouling..synthetic has the highest flash point,followed by heavier oils like 20W-50,SAE 30W...diesel 15W-40 has a high flash point too,but can loosen sludge up in a dirty old motor,might not be a good idea..I have see it free up stuck rings in one motor I had though,that I didn't care if it blew!..it practically cured its smoking and plug fouling problems..:crazy:
  12. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    New set of valve stem seals (umbrella posi type) would help your fouling problem. Before I rebuilt the top end of the 350 in my old K5, all my plugs looked like #8 and #6. Truck had the nickname of "Skeeter killer" at the shop :P
    I ended up replacing the heads and a new cam/lifters while I was at it. Once I pulled the heads off, it was just easier slapping on some relatively new ones I had laying around instead of doing the whole valve job.
    It is possible to change your stem seals without taking the heads off. You just need the "other" valve spring compressor tool (the one that doesn't wrap around the whole head). New set of stem seals doesn't cost that much, either.
  13. Scuba Steve
    Jul 17, 2002
    99
    Fort Bragg, NC
    Well this is good news. I could replace the seal but this gives me a reason for new heads. What do you guys think World S/R torquers w/ 67 cc chamber or Edelbrock performers w/ 70cc chamber
  14. kgblazerfive
    kgblazerfive keymaster Premium Member GMOTM Winner
    Dec 2, 2004
    10,621
    610
    Hooper, Utah 84315
    I have a motor that I drove on for a long time that lts plugs looked like that go with the hotter plug in the bad cylinders they work well. I would go for the World but then you open up a whole lot more things to do also.
