Temp gauge for CUCV
Discussion in '1982-Present GM Diesel' started by Mastiff, Dec 15, 2006.
  1. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Are there any spots left on the CUCV 6.2 for a temp sending unit? I believe there's already one for the idiot light and one for the injector pump?
  2. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    Why not use the one for the idiot light?
    From having mine apart I can say yes but I'm hesitant to suggest one because mine is still apart and I'm not sure of other obstructions.
    Just poke around;) If you can weld a bung on there are several more:D
  3. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    I thought about using the idiot light spot, but I'd like to keep the original gauges/lights functional if possible.
  4. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I believe there is something you can use there that lets you keep both, I think the sender for the guage has also a light provision, it comes on when it gets to 250
  5. ccatlett1984
    ccatlett1984 1/2 ton status
    May 1, 2005
    161
    michigan
    the temp sender for the idiot light goes into a small plate on the rear of teh engine, on the opossing side of the engine there is a block off plate. you simply remove the block off plate and get another threaded one from the dealer.
  6. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Interesting. Any idea of part # or application or anything?
  7. dieselponyexpress
    dieselponyexpress 1/2 ton status
    Jan 26, 2004
    220
    Germany
    Do you want a gauge for water or oil temp?
    Walter
  8. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Water.
  9. dieselponyexpress
    Jan 26, 2004
    220
    Germany
    water temp (idiot) light = left lower corner of speedometer = sending unit on left cylinder head right beneath the first glow plug.
    Maybe you could change this to a light/gauge combo unit.
    My temp sending unit is installed on left side cyl head near the firewall. It's the place for the temp switch for the glow plug harness. However I went to manual glow long time ago, this seemed to be the perfect spot for my temp switch.
    Walter
