Temp gauge reading really high
Discussion in 'The Garage' started by scooter122983, Oct 31, 2006.
  1. scooter122983
    scooter122983 1/2 ton status
    Oct 4, 2006
    297
    Fond du Lac, WI
    I have owned my truck for a year now and for most of its life the temp gauge has read high. Not just in the red but the pointer is pointing directly to the right. What do I need to do about this problem its pretty annoying not knowing my water temp.
  2. dremu
    Feb 27, 2000
    15,957
    448
    East of San Francisco
    Sender is dead, or the wire is disconnected. Fix the wiring and/or replace the sender. Possible the gauge is bad or the cluster wiring is flaky, but I've not seen that happen.
    Should be, depending on the truck, a green wire going to a sender on the driver's side of the block, in with the spark plugs.
    -- A
  3. obijuan
    obijuan 1/2 ton status GMOTM Winner
    May 18, 2006
    4,009
    San Antonio TX
    try an aftermarket one, theyre much more accurate and fairly inexpensive and easy to install.
