Temp gauge
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Slayer, Nov 15, 2001.
  1. Slayer
    Slayer 1/2 ton status
    Oct 17, 2001
    225
    Eastern Colorado, jokingly referred to as Western
    The new temperature sending unit does not work with my OEM temp gauge. The OEM gauge is '77 and the new sending unit came with my new crate motor. The guys at GM Performance are working the issue, but it's been almost a month, and no replies from the "experts" yet.
    Any ideas? I'll gladly replace my stock gauge with an Auto Meter unit if I knew that it would work with the new GM temp sending unit. But hey, at least the new motor's running good.
    L8r, Slayer
    I don't know everything, I just think that I do.............
  2. Itali83
    Itali83 1/2 ton status
    Feb 12, 2001
    795
    Westbrook Maine
    You spent a lot of money on a new motor, spend a few more on autometer MECHANICAL guages, forget electric. I just installed mechanical autometer guages in my truck, check them out at my website <a target="_blank" href=http://www.bens87toy.alloffroad.com>www.bens87toy.alloffroad.com</a> I put them on my old motor with over 100K on it, so you with a new motor, DEFINITLY GET MECHANICAL! just my .07 cents.
    Ben 87 Jimmy
    <font color=blue>Rust=Bad</font color=blue>
  3. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Autometer includes the senders with their gauges. I had a similar problem trying to get the large style 70's sender to work with my '82's gauge. What I did is grabbed an ohm meter and headed down to the part store. Gimme the sender that originally fit my truck and give me all the senders in the store that will fit the hole in my cylinder head. Then I just went down the line with an ohm meter till I found a match.
    "I ain't nobody, dork."
    <a target="_blank" href=http://www.geocities.com/bigkern76>http://www.geocities.com/bigkern76</a>
